Arc Catalog will open. When I click on a file to open Arc Map 10.7 it will load but then never opens. Was working okay last week.
Can you test your ArcMap this way? Go to the C:\Program Files (x86)\ArcGIS\Desktop10.7\bin directory and double click on ArcMap.exe. Does it start? Please advise.
Thank you for responding! The only files available is the ArcMap application and then ArcMap.exe.config and neither will open.
ArcCatalog 10.7.1 is now doing the same thing.
Okay try this - go to your C:\Users\<user profile>\AppData\Roaming and C:\Users\<user profile>\AppData\Local directories and rename the Esri folder to Esri_Old. Then try to start the ArcMap and ArcCatalog applications. What is the result?
Thank you for all your assistance Robert. So I completed this task. It allowed Catalog to open up again, but Map will initialize, load but then doesn't open the program. Within Catalog - when I try to expand certain files it will attempt to load it but on certain folders will crash.
I ran into this problem, and reading the posts here triggered my memory of an old solution that worked for me. Navigate to your Normal.mxt at C:\Users\<your login>\AppData\Roaming\ESRI\Desktop10.7\ArcMap\Templates\ and rename it or delete it. Next time you start ArcMap it will make a new Normal.mxt, and in my case started without problem.
The same holds true for ArcCatalog.gx in C:\Users\hunterr\AppData\Roaming\ESRI\Desktop10.7\ArcCatalog.
That fix did not work for me.
Me either.
