| type | name | label | readonly | calculation |
| select_one shrub_species | sp1 | select species | | |
| begin repeat | shrub_intercepts | enter intercepts | | |
| text | shrub_species | selected shrub species | yes | ${sp1} |
| integer | int_start_cm | start CM | | |
| integer | int_end_cm | end CM | | |
| end repeat | | | | |
Surveyors don't want to continually select a shrub_species inside the repeat each time they advance the repeat. They want select it 1 time (outside the repeat), then set multiple int_start_cm / int_end_cm values inside the repeat.
Everything works as-expected until they want to switch the select_one shrub_species in the top dropdown box.
If you back arrow < to the previously entered repeat records, they display the currently selected sp1 value, not the value that was selected when they were added.
Luckily, after submitting and syncing the data, the database displays the correctly selected sp1 value.
Anyone have a workaround so that field staff can page backward through the repeat and see what sp1 value was set?
