OS version: Win10 Pro 1909
Conda version: 4.8.3
python version: 3.7.4
Ran conda cmd:
conda install -c esri arcgis fastai pillow scikit-image
Opened notebook and import commands failed:
Tried removing and installing again but no luck.
Don't pip install if at all. When using conda, stick with it.
conda update numpy --no-pin --dry-run
will show you what it will install.... numpy 1.18.1 is the latest version on the anaconda site, It is what I am using. 1.18.4 is due out soon, but Anaconda hasn't been updating their site as quickly, for obvious reasons.
Should it show numpy 1.18.1 remove the --dry-run portion and update.
Esri tends to be a bit slower on the updates for things like numpy and the various science packages.
The esri-Anaconda site shows that Pro 2.6 is due for beta soon
https://anaconda.org/Esri/repo
and it looks like they won't even be moving to python 3.7 and are probably sticking with python 1.16.5 based on the
'pinned' file (numpy 1.16.* in you C:\...your_install_path...\bin\Python\res\pinned
It is there... check your version and install path
arcgis<SPAN class="punctuation token">.</SPAN>__version__ <SPAN class="string token">'1.8.0'</SPAN> <SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>learn <SPAN class="keyword token">import</SPAN> EntityRecognizer dir<SPAN class="punctuation token">(</SPAN>arcgis<SPAN class="punctuation token">.</SPAN>learn<SPAN class="punctuation token">.</SPAN>EntityRecognizer<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'__class__'</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> snip<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="string token">'_arcgis_init_callback'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_check_backbone_support'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_check_requisites'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_check_tf'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_create_emd'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_create_emd_template'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_create_html'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_create_tfonnx_emd_template'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_extract_entities_text'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_find_lr'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_get_emd_params'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_get_post_processed_model'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_get_tfonnx_emd_params'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_model_metrics'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_post_process_address_df'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_post_process_non_address_df'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_publish_dlpk'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_save'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_save_as_tfonnx'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_save_model_characteristics'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_save_tflite'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_show_lr_plot'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_write_emd'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'extract_entities'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'fit'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'from_model'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'load'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'lr_find'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'save'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'show_results'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'unfreeze'</SPAN> <SPAN class="punctuation token">]</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
It is not because the version conda is installing in 1.6.0 not 1.8.0
While the anaconda site says it is at 1.8.0...only 1.6.0 gets installed
When I manually try to install the tarball I receive more errors
I think this is a Numpy version error as that one also is not updating to the latest (1.18) so there is something going on with my machine.
I will keep digging....
Thanks Dan,
I meant to use conda, my fault. I ended up cleaning up my env for conda and restarting then retrying and that seemed to clear things up a bit. I am able to import the EntityRecognizer now and the version are good so far.
