Greetings my friends.
Is there a way to autocheck a field with only one choice?
For exemple, we need the field "Variedade" atomatic check "CTC4".
Hi Marcos,
You can set a default value for the question, if it needs to be checked when the form is loaded. You can also use a calculation to set the value based on the response to a previous question.
