Hello I would like to add image to content via python api. But as i see image does not supported. Are there any way to add image via api ?
Yes you can add an image to your content using the ArcGIS API for Python. For example:
<SPAN class="keyword token">from</SPAN> arcgis <SPAN class="keyword token">import</SPAN> GIS gis <SPAN class="operator token">=</SPAN> GIS<SPAN class="punctuation token">(</SPAN>username<SPAN class="operator token">=</SPAN><SPAN class="string token">'username'</SPAN><SPAN class="punctuation token">,</SPAN> password<SPAN class="operator token">=</SPAN><SPAN class="string token">'password'</SPAN><SPAN class="punctuation token">)</SPAN> image_item <SPAN class="operator token">=</SPAN> gis<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">.</SPAN>add<SPAN class="punctuation token">(</SPAN> item_properties<SPAN class="operator token">=</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">'type'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'Image'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> data<SPAN class="operator token">=</SPAN><SPAN class="string token">'path_to_image_file'</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
