Trying to republish a survey, no data to get overwritten , but it gets hung up when trying to delete a service item.
Can you try manually deleting the form item, feature layer and folder by logging into ArcGIS Online's website and going to 'My Content'? You should then be able to republish.
Deleted form item and feature layer, but it still get's hung up
Can you try to also delete the .iteminfo file in the survey directory? If that does not work, can I ask you to do an attempt while enabling logging (you can enable logging from the settings button on the gallery page; go to the 'Diagnostics' tab).
Can you please remind me where the survey directory is?
Is the reason the publishing gets hung up because the feature layer has a view of the feature layer, via a stakeholder layer? and/or the feature layer is being used by an AGOL map?
I deleted these items and now I no longer have a survey. Luckily I created a copy before doing the deleting. But I still cannot publish my survey!
Hi Carl,
That should not be an issue, Survey123 Connect can publish over an existing survey that has views. If you're still having problems, it might make sense to open an issue with Esri Technical Support so this behavior can be debugged.
James and Carl. I did speak with technical support and the problem is a bug in the optional "other" field.
So I had to delete the "other" text and then retype it again. This happened to me twice so I applied the same fix and it worked both times.
ragreenw_Nursing, what do you mean delete "other" text and retype it? In the label field of Survey123 Connect?
