Greeting,
I recently updated my survey 123 app(1.1.16) and desktop software(1.1.19). My app now takes nearly a minute to load every time. Previously they were loading within 5-10 seconds. Additionally, Survey123 website also exhibits a latency I did not encounter before. Is this a known problem or it is on my end? My xlsForm is attached
Thank you.
Hi Daniel,
not your fault! The survey loading time has increased since we updated to v 18. We are working on getting this back in track.
Ismael
Ismael - Is there a resolution to this problem? I was planning on using Survey123 in the field next week, but the 90 second - 2+ minute delay time for EVERY reload of the survey makes this tool unusable. I submitted an incident report to Esri Tech Support this morning (see below), but have not received any reply yet. Can you help? I need to make a go/no-go decision on whether to use Survey123 or revert to paper forms by tomorrow.
Michael
Submission Type
Incident
Problem Description
Survey123 Excessive Startup Time
Detailed Description
We plan to use Survey123 for in-the-field interviews to be conducted the week of 30 November. I created a survey called "JMH Parking" and successfully published it to ArcGIS Online. However, when I use the survey it takes a very long time (2 - 3 minutes) to load. The survey does finally load and works fine. After entering data and submitting the survey, it still takes 2 - 3 minutes to again load the survey for the next interview. This excessive startup time will make Survey123 unsuitable for use in the field.
While I'm not sure what esri may be doing to improve this, I'm still seeing the delay.
A few things that have helped me and you might be able to implement depending upon your survey configuration:
Reduce the number of items in pick lists
Separate into multi surveys
Also, are you up to date on versions both desktop and mobile? Maybe that would help? I know an update was pushed to my phone on the 17th. It looks like Survey123 website got an overhaul last week. Maybe some additional behind the scenes updates were implemented too.
We have crews out in the field so I didn't want to redownload the desktop app but maybe the desktop version has been updated? I couldn't see a version while browsing the website.
My 2 cents.
Thanks for the prompt reply, Daniel!
Re: Reducing the # of pick-list items, that isn't a viable option for me. We have a fairly long list of items for questions like "Where did you park?" and "Which building are you go to?" and we can't reduce the list. Ditto for separating into more than one survey, we need all the questions answered by the same respondent, and we can expect them to hang around while we switch surveys.
Re: Software versions, I have the latest version of the mobile app, but my desktop app was download on 23 October. I'll try downloading a new version of the desktop app and see if that makes any difference.
Would still like to hear from Ismael on this issue, given that it was a known problem that was being addressed...
Daniel - I just downloaded and installed new desktop app (1.1.30) and confirmed that I am using the latest mobile version (1.1.18). No improvement in survey startup time.
I am also experiencing prolonged loading times with updates like Michael above.
This is coming at an inopportune time as I am convincing a team to invest in this path and forms that were loading quickly now take 2-3 minutes to load, making a paper form faster to fill out.
Any progress on this issue?
Hi Joseph, we are working on improving the performance issues but will not have any updates on this until Feb 15.
If you share the Form with us we will certainly use it to validate our progress with the performance improvements.
Ismael,
Thanks!
That fact will help with my demo this evening, but the breeding frogs don’t wait for us when it rains ☺
Joe
Thanks for the heads up, standing by until your update, aim for the 14th of Feb and call it a Valentine.
The Survey123 field app has been just updated in the Google Play and Apple app stores. The latest update's version number is 1.2.49. We think you will like the improvements. More performance boosts are planned. Thanks for your patience.
