as you see on the picture, linear features are not symbolised, if I use a dynamic map, I get the symbols. the FeatureLayer shows the symbols of the points but the symbols of linear features.
Pierre-Jean,
Are you using an advanced cartographic line symbol in your map services mxd?
Or are you saying that you DO get the line symbology to show when using ArcGISDynamicMapServiceLayer but when you use FeatureLayer you do not?
no advance cartographique line, it is just a standard arrow. Yes I get the good symbology if I use ArcGISDynamicMapServiceLayer. But I need to use the featureLayer.
When you use FeatureLayer you will have to specify the symbology for the layer in your code. When using ArcGISDynamicMapServiceLayer the layer is drawn on the server and it uses the symbology specified in the mxd.
I used featureLayer for the points and the surface, it always get the symbols. We find the problem only for the linear feature.
