import arcpy # your data: tbl = r'C:\Project\_Forums\_maxDict\fgdb\test.gdb\aTable2' fld_freq = 'Frequency' fld_mapcode = 'Map_Code' fld_datasource = 'DataSource' # create empty dictionary to store results dct = {} # loop through table flds = (fld_freq, fld_mapcode, fld_datasource) with arcpy.da.SearchCursor(tbl, flds) as curs: for row in curs: freq = row[0] mc = row[1] ds = row[2] if mc in dct: freq_tot = dct[mc][0] + freq lst_ds = dct[mc][1] lst_ds.append(ds) dct[mc] = (freq_tot, lst_ds) else: dct[mc] = (freq, [ds]) # print results for mc, val in dct.items(): lst_ds = sorted(set(val[1])) # make a unique sorted list freq_tot = val[0] print freq_tot, mc, ";".join(lst_ds)
import arcpy, os arcpy.env.overwriteOutput = True # your data: tbl = r'C:\Project\_Forums\_maxDict\fgdb\test.gdb\aTable2' fld_freq = 'Frequency' fld_mapcode = 'Map_Code' fld_datasource = 'DataSource' # extra vars for output table out_ws = r'C:\Output' # r'C:\Project\_Forums\_maxDict\fgdb\test.gdb' tbl_name = 'mmc2.dbf' # 'mmc2' # create empty dictionary to store results dct = {} # loop through table flds = (fld_freq, fld_mapcode, fld_datasource) with arcpy.da.SearchCursor(tbl, flds) as curs: for row in curs: freq = row[0] mc = row[1] ds = row[2] if mc in dct: freq_tot = dct[mc][0] + freq lst_ds = dct[mc][1] lst_ds.append(ds) dct[mc] = (freq_tot, lst_ds) else: dct[mc] = (freq, [ds]) # write results to table arcpy.CreateTable_management(out_ws, tbl_name) tbl_out = os.path.join(out_ws, tbl_name) arcpy.AddField_management(tbl_out, fld_mapcode, "Text", 9, "", 10, "", "NULLABLE", "") arcpy.AddField_management(tbl_out, fld_freq, "LONG", 9, 0, "", "", "NULLABLE", "") arcpy.AddField_management(tbl_out, fld_datasource, "Text", 9, "", 255, "", "NULLABLE", "") # we still have the var flds with arcpy.da.InsertCursor(tbl_out, flds) as curs: for mc, val in dct.items(): lst_ds = sorted(set(val[1])) freq_tot = val[0] row = (freq_tot, mc, ";".join(lst_ds)) curs.insertRow(row)
import arcpy, os, numpy arcpy.env.overwriteOutput = True # your data: tbl = r'C:\Project\_Forums\_maxDict\fgdb\test.gdb\aTable2' fld_freq = 'Frequency' fld_mapcode = 'Map_Code' fld_datasource = 'DataSource' # extra vars for output out_ws = r'C:\Output' # r'C:\Project\_Forums\_maxDict\fgdb\test.gdb' tbl_name = 'mmc2.dbf' # 'mmc2' # create empty dictionary to store results dct = {} # loop through table flds = (fld_freq, fld_mapcode, fld_datasource) with arcpy.da.SearchCursor(tbl, flds) as curs: for row in curs: freq = row[0] mc = row[1] ds = row[2] if mc in dct: freq_tot = dct[mc][0] + freq lst_ds = dct[mc][1] lst_ds.append(ds) dct[mc] = (freq_tot, lst_ds) else: dct[mc] = (freq, [ds]) # create list for use in numpy; each item is a tuple of frequency, map code and list of datasources lst_out = [(val[0], mc, ";".join(sorted(set(val[1])))) for mc, val in dct.items()] # convert the list to a numpy array npa = numpy.array(lst_out, numpy.dtype([(fld_freq, numpy.int32), (fld_mapcode, '|S9'), (fld_datasource, '|S255')])) # store the table arcpy.da.NumPyArrayToTable(npa, os.path.join(out_ws, tbl_name), flds)
