Hi, I have the same problem. Is there a good solution or workround for this? Because the Geodatabase I manage and cause this problems is with replica and very large and important to just export and import for X-Ray to change the structure.
BR,
Tiina
You may want to consider using X-Ray to dump the geodatabase structure, modify it, and reload the data into the fixed copy.
X-Ray for ArcCatalog
https://www.arcgis.com/home/item.html?id=9ea218ff575f4a5195e01a2cae03a0ae
Thank you for explaining the why - that is helpful in avoiding this in the future. That being said, how do we delete the domain? Is it possible? I'd appreciate any feedback and thank you,
Emily
Depending upon the way the domains / domain names were originally entered I have seen this behavior when a domain exists that has a carriage return present. This typically occurs when domain names are copied from sources like Microsoft Excel where carriage returns may be hidden and often times they are not immediately visible when viewing domain properties within ArcCatalog. There is a defect addressing this behavior for Oracle enterprise geodatabases (but it might well affect file geodatabases as well). If values have been copied / pasted opposed to manually entered for domain names- I'd consider this a high possibility:
BUG-000091839:
Updating or deleting a domain created with a carriage return returns the error, "Failed to update one of the domains. The domain was not found."
It's file geodatabase
What kind of a database is being used here?
Can I answer, if you don't mind?
1. I use ArcGIS Desktop v.10.5
2. It's range domain of small integer type
3. No, domain not assined to any feature class
4. Yes, it does
Tom,
~Shan
So... after 6 years... Maybe ESRI answer us what to do with this problem?
Hi, I am having a same problem. Any one figured out this solution? Thanks.
