These two numbers dictate how much you can zoom in/out. I cannot tell you a set of reasonable values for these properties as it would depend on the layers contained in your map. If your map contains tiled layer, you may not need to update the map's Minimum and MaximumResolution http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Map~MaximumResolution.html.
The problem I'm having is why the same setting values behave differently in Arcgis 9 and 10. In my code, I don't know how I can detect it is Arcgis 9 or 10 😞 so that I can set them differently. If you know, please let me know. It has driven me crazy for a simple feature.I'm not using a tile layer.Thanks!
