Hi,I'm trying to write a script to count the number of feature classes in a dataset so that I can delete any datasets that have a count of 0 feature classes.this forms the last part of the script below:import arcpy
from arcpy import env
# Sets the workspace
env.workspace = "L:\TEMP\test_Database_working.gdb"
# lists all feature classes in the workspace (geodatabase)
listFCs = arcpy.ListFeatureClasses("*")
# lists all feature datasets in the workspace (geodatabase)
listFDs = arcpy.ListDatasets("*")
# loops through the Feature Class list and deletes any with 0 features
for fc in listFCs:
count1 = str(arcpy.GetCount_management(fc))
if count1 == "0":
arcpy.Delete_management(fc)
# loops through the Feature Dataset list and deletes any with 0 feature classes
# this part contains errors but shows what I'm attempting to acheive
for dataset in listFDs:
count2 = str(arcpy.GetCount_management(dataset))
if count2 == "0":
arcpy.Delete_management(dataset)
How can I fix the last part as 'GetCount_management' does not work?Thanks!Mick
