import os, multiprocessing, arcpy def project(raster): arcpy.ProjectRaster_management(raster...) def main(): workspace = r'c:\somepath' arcpy.env.workspace = workspace fcs = arcpy.ListRasters('*') fc_list = [os.path.join(workspace, fc) for fc in fcs] pool = multiprocessing.Pool() pool.map(project, fc_list) pool.close() pool.join()if __name__ == '__main__': main()
File "C:\Python26\ArcGIS10.0\lib\multiprocessing\process.py", line 232, in _bootstrap self.run() File "C:\Python26\ArcGIS10.0\lib\multiprocessing\process.py", line 88, in run self._target(*self._args, **self._kwargs)File "C:\Python26\ArcGIS10.0\lib\multiprocessing\pool.py", line 57, in worker task = get() File "C:\Python26\ArcGIS10.0\lib\multiprocessing\queues.py", line 352, in get return recv() AttributeError: 'module' object has no attribute'project'
import os, multiprocessing, arcpy def project(rasterin, rasterout): arcpy.ProjectRaster_management(rasterin, rasterout,#�?� # just return something; will print once done return �??converted: %s and made output: %s�?? % (rasterin,rasterout) if __name__ == �??__main__�??: workspace = r�??d:\Temp\dems�?? arcpy.env.workspace = workspace fcs = arcpy.ListRasters(�??*�??) pool = multiprocessing.Pool() jobs = [] # iterate through features, add input and output paths for fc in fcs: rIn = os.path.join(workspace, fc) rOut = os.path.join(r�??d:\Temp\demsOut�??, fc) jobs.append(pool.apply_async(project, (rIn, rOut))) for job in jobs: print job.get()
ERROR 010302: Unable to create the output raster: C:\Data\sr6f8~1\FocalSt_srtm1 ERROR 010067: Error in executing grid expression. Failed to execute (FocalStatistics).
