The only storytelling template that has a spash screen currently is the storytelling tabbed one. And you are right, it's very basic in terms of the text. It doesn't support carriage returns. The storytelling text and legend template, while it doesn't have a spash screen, displays the description of the map. In this case, the text formatting is preserved. If you know a bit of programming, you could download the template and customize it. You'd have to then host it on your own web server.Thanks,Mike
I have a google analytics script to be added to a webmap. As you know, it's a script that needs to run once for every access. Can I use the "Attach code" functionality to collect statistics on the webmap?
