There are all sorts of posts on how to properly format code in messages, like https://community.esri.com/people/curtvprice/blog/2014/09/25/posting-code-blocks-in-the-new-geonet
But, how do I copy the code to use on my system? The code contains unwanted characters when I highlight/copy and paste it into a text editor. For example, see the useful code at https://community.esri.com/thread/180215#comment-623464 which also contains long wrap-around lines.
Thanks.
Bruce,
That's a great question. I wonder if you can copy and paste the code into a code editor and have code editor parse out the unwanted things (especially if it's all the same unwanted thing). Or maybe paste it into something MS Word and do a find and replace for "..." or so. Either way, I bet some people here have a good answer.
This example
import numpy as np from numpy.lib.stride_tricks import as_strided from functools import wraps from textwrap import dedent np.set_printoptions(edgeitems=3,linewidth=80,precision=2, suppress=True,threshold=100)
looks like his
<pre class="jive_text_macro jive_macro_code " jivemacro="code" ___default_attr="c#" data-renderedposition="34_8_916_96" >
<p>import numpy as np</p>
<p>from numpy.lib.stride_tricks import as_strided</p>
<p>from functools import wraps</p>
<p>from textwrap import dedent</p>
<p>np.set_printoptions(edgeitems=3,linewidth=80,precision=2,</p>
<p> suppress=True,threshold=100)</p>
</pre>
<p></p></body>
So I just use Notepad++ or whatever and replace the <p>, </p> etc stuff
Actually I have a script somewhere that does similar stuff.
As for wrap around text and multilines, you may have to do some text editing, but be careful of trying to strip too much away
I am a little confused here. When I copy from a Jive/GeoNet code block I do not get any extra html formatting tag or unwanted stuff.
Robert,
Take a look at Darren's reply here:
There are ... before each line. These would get picked up in a copy/paste
It sometimes depends where you past it Robert, some destinations hide and interpret the paste as valid html code and hence it isn't visible. Notepad++ has a whole slew of conversion options that does the automagic stripping, and if that doesn't work, then it has some pretty powerful text editing capabilities. And you can even run code snippets in several languages, if one gets lazy
I just happened to be working on this very code block and noticed the exact same thing. If you copy it into the Python window in ArcMap (where it was made), it goes in smoothly, but if you try to edit it in an IDE, the ... are problematic. As Adrian suggested, I replaced all '... ' with '' (blank) to remove them.
Here's the updated code, but I'm not sure what the best code use advice would be.
lines = 'a_line' # line feature class sr = arcpy.Describe(lines).spatialReference # spatial reference new_polys = [] new_scratch_polys = [] new_lines = [] buffers = [] max_buff = 50 # buffer at line start min_buff = 10 # buffer at line end with arcpy.da.SearchCursor(lines,'SHAPE@',spatial_reference=sr) as cursor: # loop through lines for row in cursor: prev_buff = None for part in row[0]: for pnt in part: cur_rad = ((max_buff-min_buff) * (1-row[0].measureOnLine(pnt,True))) + min_buff # calc current proportional buffer size cur_buff = arcpy.PointGeometry(pnt,sr).buffer(cur_rad) # create buffer geometry new_poly_array = arcpy.Array() if prev_buff: # if at least second vertex cur_poly = cur_poly.union(cur_buff) # add buffer to cumulative geometry c1 = prev_pnt # previous point center c2 = pnt r1 = prev_rad r2 = cur_rad dx = c2.X - c1.X dy = c2.Y - c1.Y dr = r2 - r1 d = math.sqrt(math.pow(dx,2)+math.pow(dy,2)) X = dx/d Y = dy/d R = dr/d ks = [1,-1] for k in ks: a = (R*X)-((k*Y)*math.sqrt(1-math.pow(R,2))) b = -((R*Y)+((k*X)*math.sqrt(1-math.pow(R,2)))) c = r1 - (a*c1.X) + (b*c1.Y) tan_x1 = c2.X-10000 tan_x2 = c2.X+10000 tan_y1 = -((((-a)*(tan_x1))-c)/(b)) tan_y2 = -((((-a)*(tan_x2))-c)/(b)) new_line = arcpy.Polyline(arcpy.Array([[arcpy.Point(tan_x1,tan_y1),arcpy.Point(tan_x2,tan_y2)]]),sr) # create line new_lines.append(new_line) if k > 0: new_poly_array.add(new_line.intersect(prev_buff,1).centroid) # find intersections new_poly_array.add(new_line.intersect(cur_buff,1).centroid) # find intersections else: new_poly_array.add(new_line.intersect(cur_buff,1).centroid) # find intersections new_poly_array.add(new_line.intersect(prev_buff,1).centroid) # find intersections new_rect = arcpy.Polygon(new_poly_array,sr) # make polygon from intersections new_scratch_polys.append(new_rect) # add rectangle to scratch geometry cur_poly = cur_poly.union(new_rect) # add rectangle to cumulative geometry else: cur_poly = cur_buff # add buffer to cumulative geometry prev_rad = cur_rad #remember values prev_pnt = pnt prev_buff = cur_buff buffers.append(prev_buff) new_polys.append(cur_poly) # add cumulative geometry to list arcpy.CopyFeatures_management(buffers,r'in_memory\buffers') # write outputs arcpy.CopyFeatures_management(new_scratch_polys,r'in_memory\scratch_polys') arcpy.CopyFeatures_management(new_lines,r'in_memory\lines') arcpy.CopyFeatures_management(new_polys,r'in_memory\polys')
Or, if you had a python IDE like Wing 101 Python IDE for Python Developers - Wingware Python IDE or any number of others (and NotePad++ probably has this), you can cut and paste and after replacing things like the ... and >>> , they usually have a conversion for the spaces to tabs if you like. Since python is very sensitive to spacing, getting this correct and set right away will hopefully cause less headaches in the end.
BTW, I copied Darren Wiens 's copy you mentioned and it took less then a minute to get the formatting cleaned up.
edit: just ran you script Darren...pretty nice - may use that at some point
Thanks Darren, this code copied and pasted correctly formatted without unwanted characters.
As others have pointed out a search and replace will work, but this seemed an unnecessary and potentially problematic step.
So, the ease of copying posted code depends on how it was posted more than the message system. I'll assume my question was answered.
Thanks everybody.
Code like this takes a few hours to put together. I hope I can count on the end user to spend a couple minutes making it fit their system.
