Hey all,I am trying to set the projection of a temp shapefile so I can add a length field. I am using the factory code to set it. I have a huge list of shapefiles in (GCS) and their corresponding ideal factory codes for State Plane CS. I am trying to loop through each and set the projection, but it only works the first time. The second time I get this error:Traceback (most recent call last): File "C:\Users\egreen\Desktop\BigFiles KEEP\CreatePROX_FINAL.py", line 67, in <module> sr = arcpy.SpatialReference(ProjCode) File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 927, in __init__ self._arc_object.createFromFile(item)RuntimeError: ERROR 999999: Error executing function.the input is not a geographic or projected coordinate systemThe error is misleading since it is not a bad factory code (or WKID). The second shapefile has the same factory code. I think the error is due to the variable sr already existing. I'm curious if I need to destroy sr somehow (I don't see a method for that though). Or am I misunderstanding this.Here's my code:
import arcpy
import xml.etree.cElementTree as ET
import os
import xlrd
from arcpy import env
import os.path
import shutil
import zipfile
import glob
#set paths to documents
myPath = os.getcwd() + "\\ScriptFiles"
excel_path = myPath + "\\Inputs.xls"
wb = xlrd.open_workbook(excel_path)
# Load XLRD Excel Reader
sheetname = wb.sheet_names() #Read for XCL Sheet names
sh1 = wb.sheet_by_index(0) #Login
#flag for first row
Skip = True
### Set Geoprocessing environments
arcpy.env.scratchWorkspace = myPath + "\\Scratch.gdb"
arcpy.env.workspace = myPath + "\\PROXCreate.gdb"
Coordinate_System = "GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]" # provide a default value if unspecified
# Set overwrite option
tmpRoads = "tmpRoads"
tmpBoundaries = "tmpBoundaries"
#Loop through Excel
for rownum in range(sh1.nrows):
rows = sh1.row_values(rownum)
#skip first row
if Skip == True:
Skip=False
else:
CountyName = rows[0]
StateName = rows[2]
InputRoadShpfl = rows[10]
InputBoundaryShpfl = rows[11]
ProjName = rows[9]
ProjCode = rows[12]
if arcpy.Exists(tmpRoads):
arcpy.Delete_management(tmpRoads)
if arcpy.Exists(tmpBoundaries):
arcpy.Delete_management(tmpBoundaries)
if (arcpy.Exists(myPath + "\\TigerFiles\\" + InputRoadShpfl)) and (myPath + "\\TigerFiles\\" + InputBoundaryShpfl):
print "Executing shapefiles:" + InputBoundaryShpfl + " & " + InputRoadShpfl + "(" + StateName + "\\" + CountyName + ")"
# Make a layer from the feature class
#arcpy.MakeFeatureLayer_management(myPath + "\\TigerFiles\\" + InputRoadShpfl, tmpRoads)
arcpy.CopyFeatures_management(myPath + "\\TigerFiles\\" + InputRoadShpfl, tmpRoads)
arcpy.MakeFeatureLayer_management(myPath + "\\TigerFiles\\" + InputBoundaryShpfl, tmpBoundaries)
# Process: Define Projection (3)
#sr = arcpy.SpatialReference(102629)
#sr = arcpy.SpatialReference(ProjName)
#sr.factoryCode = ProjCode
sr.create()
arcpy.DefineProjection_management(tmpRoads, sr)
