//Execute a routing task when clicking "get direction". getDirections:function () { console.log("hello where are you"); routeParams.stops.features = []; this.map.graphics.clear(); //Get origin address. var optionsFrom = { address:{"SingleLine":dojo.byId("fromTxf").value}, outFields:["*"] } var fromAddress = locator.addressToLocations(optionsFrom); //Get destination address. var optionsTo = { address:{"SingleLine":dojo.byId("toTxf").value}, outFields:["*"], } var toAddress = locator.addressToLocations(optionsTo); //Create a deferred list with the dojo.deferred objects of fromAddress and toAddress, then find the route. /* all([fromAddress,toAddress]).always(function(results){ }); }*/ var dList = new dojo.DeferredList([fromAddress,toAddress]); dList.then(configureRoute); }
var //Create a deferred list with the dojo.deferred objects of fromAddress and toAddress, then find the route. var all = new All([fromAddress,toAddress]); all.always(configureRoute); };
//anonymous function to load CSS files required for this module ( function() { var css = [require.toUrl("parking/digit/DrivingDirections/css/DrivingDirections.css")], head = document.getElementsByTagName("head").item(0), link; for (var i = 0, il = css.length; i < il; i++) { link = document.createElement("link"); link.type = "text/css"; link.rel = "stylesheet"; link.href = css.toString(); head.appendChild(link); } }()); return declare([_WidgetBase, _TemplatedMixin, _WidgetsInTemplateMixin, Evented], { templateString : template, widgetsInTemplate : true, baseClass : 'DrivingDirections', options : { map : null, extent : null }, constructor : function(options) { declare.safeMixin(this, options); this.set("map", options.map); }, startup : function(){ on(dom.byId("directions"), "click", this.getDirections); }, postCreate : function() { if (writeLog) console.log("Driving Directions");//fill in the blank with a task function from index11.html...//function init() { // on(dojo.byId("directions"), "onclick", getDirections); //on(dom.byId("directions"), "click", getDirections); //Set up the URL to the proxy page. // esri.config.defaults.io.proxyUrl = "/proxy"; //Proxy added on Controller.js //Create a map with an initial extent. Change the extent to match the area you would like to show. //map added on Controller.js /* map = new esri.Map("map", { basemap: "streets", center: [-98.49946448681641, 29.4205708789947], zoom: 13, sliderStyle: "big" });*/ //Add a geocoding server as the locator. This locator will be used to find the origin and destination coordinates by input addresses. locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"); locator.outSpatialReference = map.spatialReference; //Fire errorHandler if the locator return en error. on(this.locator, "error", errorHandler); //locator.on("error", errorHandler); //Add a network analyst server with related parameters to execute the routing task. routeTask = new RouteTask("http://tasks.arcgisonline.com/ArcGIS/rest/services/NetworkAnalysis/ESRI_Route_NA/NAServer/Route"); routeParams = new RouteParameters(); routeParams.stops = new FeatureSet(); routeParams.returnRoutes = false; routeParams.returnDirections = true; routeParams.directionsLengthUnits = units.MILES; routeParams.outSpatialReference = new SpatialReference({ wkid:102100 }); //Show the route when the routing task is solved successfully, otherwise fire errorHandler. // on(this.routeTask, "SolveComplete", showRoute); // on(this.routeTask, "error", errorHandler); //routeTask.on("solve-complete", showRoute); //} // dojo.ready(init); //Check if the origin and destination addresses are executed successfully //and solve the routing task. function configureRoute(results) { //Configure symbols to be used for destinations and route segments. var fromSymbol = new PictureMarkerSymbol({ "angle":0, "xoffset":0, "yoffset":10, "type":"esriPMS", "url":"http://static.arcgis.com/images/Symbols/Transportation/GreenSquareDaymark.png", "contentType":"image/png", "width":24, "height":24 }); var toSymbol = new PictureMarkerSymbol({ "angle":0, "xoffset":0, "yoffset":12, "type":"esriPMS", "url":"http://static.arcgis.com/images/Symbols/Transportation/RedSquareDaymark.png", "contentType":"image/png", "width":24, "height":24 }); var fromStop = checkCandidate(results[0][1]); if (fromStop===null) { errorHandler("The origin address is invalid"); } else { var fromGraphic = new Graphic(fromStop.location, fromSymbol, { address:fromStop.address }); routeParams.stops.features[0] = map.graphics.add(fromGraphic); }; var toStop = checkCandidate(results[1][1]); if (toStop===null) { errorHandler("The destination address is invalid"); } else { var toGraphic = new Graphic(toStop.location, toSymbol, { address:toStop.address }); routeParams.stops.features[1] = map.graphics.add(toGraphic); }; if (fromStop!==null && toStop!==null) { routeTask.solve(routeParams, showRoute, errorHandler); } } //Handle all the coordinate candidates of the origin and destination addresses and //return the candidate with the highest score. function checkCandidate(candidate){ var stop = null, score = 0; dom.forEach(candidate, function(candidate){ if(candidate.score > score){ stop = candidate; score = candidate.score; } }); return stop; } //Show the result of the routing task. function showRoute(solveResult) { var data = []; if(grid) grid.refresh(); var directions = solveResult.routeResults[0].directions; directionFeatures = directions.features; var routeSymbol = new SimpleLineSymbol().setColor(new Color([0,0,255,0.5])).setWidth(4); //Add route to the map. var routeGraphic = new Graphic(directions.mergedGeometry, routeSymbol); map.graphics.add(routeGraphic); routeGraphic.getDojoShape().moveToBack(); map.setExtent(directions.extent, true); //Display the directions. var directionsInfo = solveResult.routeResults[0].directions.features; var totalDistance = number.format(directions.totalLength); var totalLength = number.format(directions.totalTime); data = array.map(directionsInfo,function(feature,index){ return { "detail": feature.attributes.text, "distance": number.format(feature.attributes.length,{places:2}), "index": index } }); grid = new Grid({ renderRow:renderList, showHeader:false },"grid"); grid.renderArray(data); } function renderList(obj,options){ var template = "<div class='detail'><div style='max-width:70%;float:left;'><a href='#' onclick='zoomToSegment(${index});'> ${detail}</a></div><span style='float:right;' class='distance'>${distance} mi</span></div>"; return domConstruct.create("div",{innerHTML:esri.substitute(obj,template)}); } //Display any errors that were caught when attempting to solve the route. function errorHandler(err) { alert("An error occured\n" + err); } function zoomToSegment(index) { var segment = directionFeatures[index]; var segmentSymbol = new SimpleLineSymbol().setColor(new Color([255,0,0,0.5])).setWidth(8); map.setExtent(segment.geometry.getExtent(), true); if (! segmentGraphic) { //segmentGraphic = map.graphics.add(new esri.Graphic(segment.geometry, segmentSymbol) segmentGraphic = map.graphics.add(new Graphic(segment.geometry, segmentSymbol)); } else { segmentGraphic.setGeometry(segment.geometry); } } //end of copy and paste for driving directions from index11.html// startup : function() { // // map not defined // if (writeLog) // console.log('LayerSearch::startup'); // if (!this.map) { // this.destroy(); // if (writeLog) // console.log('LayerSearch::map required'); // } // }, // destroy : function() { // this.inherited(arguments); // }},///had .promise info here////Execute a routing task when clicking "get direction". getDirections:function () { // function getDirections() { console.log("hello where are you"); routeParams.stops.features = []; map.graphics.clear(); //Get origin address var optionsFrom = { address:{"SingleLine":dom.byId("fromTxf").value}, outFields:["*"] } var fromDeferred = new deferred(); var fromAddress = locator.addressToLocations(optionsFrom); //Get destination address. var optionsTo = { address:{"SingleLine":dom.byId("toTxf").value}, outFields:["*"], } var toAddress = locator.addressToLocations(optionsTo); //Create a deferred list with the dojo.deferred objects of fromAddress and toAddress, then find the route. all([fromAddress.promise,toAddress.promise]).then(configureRoute); } /* var dList = new dojo.DeferredList([fromAddress,toAddress]); dList.then(configureRoute); }*/ });//end declare });//end define
require(["dojo/promise/all"... ... var fromAddress = locator.addressToLocations(optionsFrom); ... all([fromAddress.promise, toAddress.promise]).then(configureRoute);
