I am not able to access that service. Is it public?Andy
Could you share the Url to your map service?Thanks,Andy
António,When features are drawn from a map service as features, they are simplified for the current map scale. This both minimizes the complexity of features being transferred from the server and improves drawing performace.Visually, you should not see any perceptable change.When you select a feature, the seleciton graphic is based on the resultion of the feature when you select it. If you subsequently zoom in, the feature will be drawn with a higher resolution geometry, but the selection graphic remains its original (lower resolution). I think this is the effect you are seeing.Andy
