I am upgrading ArcMap from 10.2 to 10.4 and want to keep my toolbars and customizations, etc.
Thanx for all your help.
Regards,
Louis L. Toscano Jr.
GIS Technician, Compliance and Technology
Brick Utilities
1551 Hwy. 88 West
Brick, New Jersey 08724-2399
732-458-7000 ext. 4242
Ltoscano@brickmua.com<mailto:Ltoscano@brickmua.com>
Thank you very much for your help!
Lou
Yes. You can replace the Normal.mxtI would suggest you to keep a backup of C:\Users\<UserName>\AppData\Roaming\ESRI\Desktop10.2. You might need the connections of ArcCatalog as well.
I would copy the current Normal.mxt at the path, below; then after updating ArcMap, I could replace the Normal.mxt that came with the update with the saved one.?
You could test the following.
Keep a backup of C:\Users\<UserName>\AppData\Roaming\ESRI\Desktop10.2.
Replacing the Normal.mxt template after the new install might work.
