map.graphics.enableMouseEvents(); dojo.connect(map.graphics, "onClick", function(evt) { map.infoWindow.setContent("<span id='spanSelectPDF'></span><span><input type='button' value='Open PDF' onclick='openPDF();' /></span>"); var URLs = evt.graphic.attributes.PDFs.split(";"); // Assumes attribute's name is 'PDFs' if (URLs.length > 1) { // More than 1 pdf, so use a select list... var selectList = $("<select id='selectPDF' />"); selectList.append($("<option selected='selected'>Select PDF</option>")); for (var i = 0; i < URLs.length; i++) { var url = URLs; selectList.append($("<option value='" + url + "'>" + url + "</option>")); } $("#spanSelectPDF").append(selectList); } else { // One (or fewer) pdfs, just put the URL in the span to display $("#spanSelectPDF").html(URLs[0]); } });
function openPDF() { var url; if ($("#selectPDF").length > 0) // Check if the select list exists url = $("#selectPDF").find("option:selected").val(); // get the value of the selected option else url = $("#spanSelectPDF").html(); // otherwise use the html we stuck in the span as the link if (url != "") // Check the url has a value, as our default option has no value (requires that the user make a selection) window.open(url); // Open the link }
