fc = "Parcels" field = "GeneratedN" cursor = arcpy.SearchCursor(fc) for row in cursor: row.getValue(field) Val = row.getValue(field) if Val == 1: print "Done" else: print "Not Done"
I want to use an if else statement to pass a condition and it's not returning any of the two values what im i doing wrong?fc = "Parcels" field = "GeneratedN" cursor = arcpy.SearchCursor(fc) for row in cursor: row.getValue(field) Val = row.getValue(field) if Val == 1: print "Done" else: print "Not Done" Any suggestions please
fc = "Parcels" field = "GeneratedN" cursor = arcpy.SearchCursor(fc) for row in cursor: Val = row.getValue(field) if Val == 1: print "Done" else: print "Not Done"
fc = "Parcels" field = "GeneratedN" cursor = arcpy.SearchCursor(fc) for row in cursor: Val = row.getValue(field) if Val == 1: print "Done" break; else: print "Not Done"
fc = "Parcels" field = "LGA" cursor = arcpy.SearchCursor(fc) for row in cursor: row.getValue(field) val = row.getValue(field) print (row.getValue(field)) field = "District" cursor = arcpy.SearchCursor(fc) for row in cursor: row.getValue(field) val1 = row.getValue(field) print (row.getValue(field)) field = "Block_No" cursor = arcpy.SearchCursor(fc) for row in cursor: row.getValue(field) val2 = row.getValue(field) print (row.getValue(field)) field = "Plot_No" cursor = arcpy.SearchCursor(fc) for row in cursor: row.getValue(field) val3 = row.getValue(field) print (row.getValue(field)) outName = str(val) + "_LGA" + "(" + str(val1) + " _Area" + ")" outName1 = "Plot_" + str(val3) + "(" "Block_" + str(val2) + ")" outName2 = "Block_" + str(val2) + "_Plot_" + str(val3) + "_" + str(val1) + "_Area_of_" + str(val) + "_LGA" + ".pdf" arcpy.CreateFolder_management("C:\\ARA_STATE\\", outName) arcpy.CreateFolder_management("C:\\ARA_STATE\\"+ outName,outName1) arcpy.mapping.ExportToPDF(mxd,"C:\ARA_STATE\TDP_For_" + outName1)
arcpy.mapping.ExportToPDF(mxd,"C:\ARA_STATE\TDP_For_" + outName,outName1)
arcpy.CreateFolder_management("C:\\ARA_STATE\\", outName) arcpy.CreateFolder_management("C:\\ARA_STATE\\"+ outName,outName1) arcpy.mapping.ExportToPDF(mxd,"C:\ARA_STATE\TDP_For_" + outName1)my final pdf output is not going into something like this arcpy.mapping.ExportToPDF(mxd,"C:\ARA_STATE\TDP_For_" + outName,outName1)What do you think?
arcpy.mapping.ExportToPDF(mxd,"C:\\ARA_STATE\\TDP_For_" + outName,outName1)
arcpy.mapping.ExportToPDF(mxd,r"C:\ARA_STATE\TDP_For_" + outName,outName1)
fc = "Parcels" field = "LGA" field1 = "District" field2 = "Block_No" field3 = "Plot_No" cursor = arcpy.SearchCursor(fc) for row in cursor: # do not use 4 cursors on the same feature class, only 1 cursor is needed. # read every cursor row and get all 4 field values in a single read of the row val = row.getValue(field) print (row.getValue(field)) val1 = row.getValue(field1) print (row.getValue(field1)) val2 = row.getValue(field2) print (row.getValue(field2)) val3 = row.getValue(field3) print (row.getValue(field3)) # The lines below must also be in the loop to use the values read from each row. outName = str(val) + "_LGA" + "(" + str(val1) + " _Area" + ")" outName1 = "Plot_" + str(val3) + "(" "Block_" + str(val2) + ")" outName2 = "Block_" + str(val2) + "_Plot_" + str(val3) + "_" + str(val1) + "_Area_of_" + str(val) + "_LGA" + ".pdf" arcpy.CreateFolder_management("C:\\ARA_STATE\\", outName) arcpy.CreateFolder_management("C:\\ARA_STATE\\"+ outName,outName1) arcpy.mapping.ExportToPDF(mxd,r"C:\ARA_STATE\TDP_For_" + outName2)
arcpy.mapping.ExportToPDF(mxd,r"C:\ARA_STATE\\" + outName + "\\" + outName1 + "\\" + "TDP_For_" + outName2)
A very big thank you to you SIR!!!! Once again you are the main man. You solved yet another problem for me!
def onEditChange(self, text): pass def onFocus(self, focused): pass def onEnter(self): pass def refresh(self): pass
Dear rfairhur24 please i want to be able to select a name from a drop down list of a combobox i created and i use to use the enter tab to set the process and not by just selecting the name. which of the following codes would i use? Thanksdef onEditChange(self, text): pass def onFocus(self, focused): pass def onEnter(self): pass def refresh(self): pass
Please start a new thread for this question. It is completely different from the other questions on this thread. Also, I am not an expert on Python custom user interface design, so I am not sure I can help. Please indicate how you created this combobox when you repost. Are you hosting the combobox using a script tool interface, a tkinter interface, or what?
