I am keep getting below error in the log file. Can someone help to get rid of this. Thank you.
My GeoEvent continues to work fine even with this "error". I quote error because after opening a ticket with esri they have informed me that this is infact mislabeled as an error and should only be a warning. That being said it does not affect my GeoEvent services so this explanation was fine with me.
MBramer-esristaff - We are having the same issue on 10.5.1 server. I can receive data over TCP port and pass it to a GeoDB table completely fine. I then have an input that is polling from that table with incremental updates every 10 seconds but it takes almost 5 minutes to grab the data and post. All the while my master GeoEvent Service model that is using the polled data never shows an increase on the inputs even though I did see the polling work. During this time I see a state suspended and state reconnected in the logs as well as the other issue that is displayed in the first post. I have to imagine that this connection loss is causing the issues. Side note, we have a similar set up on GeoEvent 10.4.1 and the issues don't seem to be happening there.
Jason
I have the same error. I am having problems polling certain feature services as well. Not sure if they are related.
Anyone figure this out?
We are experiencing the same issue. Have you managed to solve this?
Can you tell us how you did this then?
Thanks.
