I've created a tool to import the RoadVista's CSV output into my sign inventory program (SignProx) but also listen for the Bluetooth message sent for every new sign and link that data to a sign location on a map. The Bluetooth data stream is pretty handy as it contains barcode, retro readings and user/standard comments. It was pretty easy to set up. See a demo here.I would be glad to help with any issues.Eric
Hi, irkgreen. You said the Bluetooth data stream contains barcode? How did you do that?Using code or a third party tool? As for barcode generation, I used to generate barcode with the help of another Barcode Generator SDK.It is just one of many but I do appreciate its simple way of processing.Even though I only tried its free trial package to generate barcodes and didn�?�t check the cost and licensing conditions, it works great for me.Besides, this barcode site gives a lot of choices for report barcoding project.But I wonder how did you do that by adding barcodes information to the bluetooth data. I have to say you did a great job! Good luck.Best regards,Arron
