Ok, looking through our bug queue, these are issues we've fixed in 10.2 or 10.2.1 (which we're working on right now, its not released yet). However, they're easy enough to work around by deleting a file When ArcCatalog opens, the tree opens to one particular folder. Make sure there are no PYTs in that folder. If there are any, move or delete them. You can find what directory this is by looking if the registry if you aren't sure: HKEY_Current_User\Software\Esri\Desktop10.1\ArcCatalog\Settings\ LastLocation or Try deleting the ArcToolbox.dat found here: C:\Users\[USER NAME]\AppData\Roaming\ESRI\Desktop10.1\ArcToolbox\ArcToolbox.dat (this will reset your ArcCatalog profile)
I've deleted the .dat file and changed the Geoprocessing results to Never Save. ArcCatalog still crashes when opened, but works just fine via ArcMap.Any ideas? Running 10.1 and did use a new tool from Esri before this started.Thanks,sk
Ok, looking through our bug queue, these are issues we've fixed in 10.2 or 10.2.1 (which we're working on right now, its not released yet). However, they're easy enough to work around by deleting a fileWhen ArcCatalog opens, the tree opens to one particular folder. Make sure there are no PYTs in that folder.If there are any, move or delete them. You can find what directory this is by looking if the registry if you aren't sure:HKEY_Current_User\Software\Esri\Desktop10.1\ArcCatalog\Settings\LastLocationorTry deleting the ArcToolbox.dat found here:C:\Users\[USER NAME]\AppData\Roaming\ESRI\Desktop10.1\ArcToolbox\ArcToolbox.dat(this will reset your ArcCatalog profile)Hope one of these helpsJoseph: could you post your PYT here for us to look at? thanks
Glad to hear!This particular issue looks to be fixed in 10.2:NIM085149 -Python toolboxes crash ArcCatalog when previously run Python toolbox tool results are saved with the application.
