GraphicsLayer _graphicsLayer; // Create an ImageBrush ImageBrush simpleArrow = new ImageBrush(); simpleArrow.ImageSource = new BitmapImage(new Uri("pack://application:,,,/Images/SimpleArrow.png", UriKind.Absolute)); // Found an image on http://www.iconfinder.com/search/?q=simple+arrow // Add an Ellipse Element & use the ImageBrush as the Fill for the Ellipse Ellipse myEllipse = new Ellipse(); myEllipse.Fill = simpleArrow; myEllipse.HorizontalAlignment = HorizontalAlignment.Center; myEllipse.VerticalAlignment = VerticalAlignment.Center; myEllipse.Width = 24; myEllipse.Height = 24; // Create a UniqueValueRenderer based on the Angle attribute/field in the underlying data var renderer = new UniqueValueRenderer() { Field = "Angle", }; // Create UniqueValueInfo objects for each integer value 0-360 and an associated PictureMarkerSymbol for each one, rotated to that value. for (int i = 0; i < 361; i++) { // Rotate by the angle 0-360 and about the center of the 24x24 pixel image. myEllipse.RenderTransform = new RotateTransform(i,12,12); //Force a render myEllipse.Measure(new Size(Double.PositiveInfinity, Double.PositiveInfinity)); myEllipse.Arrange(new Rect(myEllipse.DesiredSize)); RenderTargetBitmap render = new RenderTargetBitmap(34, 34, 96, 96, PixelFormats.Default); render.Render(myEllipse); // Create a PictureMarkerSymbol PictureMarkerSymbol pms = new PictureMarkerSymbol() { Source = render, }; // Create the UniqueValueInfo UniqueValueInfo uniqueValueInfo = new UniqueValueInfo() { Value = i, Symbol = pms, }; // Add the UniqueValueInfo to the Infos property on the renderer renderer.Infos.Add(uniqueValueInfo); } // Create a new GraphicsLayer _graphicsLayer = new GraphicsLayer(); // Create a instance of the Random class to generate random coordinate pairs. Random random = new Random(); // Add graphics to a List<Graphic> var graphicsList = new List<Graphic>(); for (int i = 0; i < 100; i++) { var x = (random.NextDouble() * 40000000) - 20000000; var y = (random.NextDouble() * 40000000) - 20000000; var graphic = new Graphic() { // assign each graphic a number 0, 1, 2 - we''ll use this to represent he color Geometry = new MapPoint(x, y), Attributes = { { "Angle", random.Next(0,361)} } }; graphicsList.Add(graphic); } // Set the renderer _graphicsLayer.Renderer = renderer; // Bulk add of graphics - more efficient than adding one graphic at a time _graphicsLayer.Graphics.AddRange(graphicsList); // Add layer to Map MyMap.Layers.Add(_graphicsLayer);
Mike,I've just run into this myself. While your solution looks like it will work for me, you mention that this was on the roadmap for the runtime sdk. As it's been a couple years since this post, I was wondering what the current status of this is?
-Chris
Yes it was added to the WPF SDK as a property on renderers - the links below relate to the SimpleRenderer:
RotationExpression Property
RotationType Property
And you will also find it in the new .NET SDK - again the example here is for a SimpleRenderer:
SimpleRenderer.RotationExpression Property
SimpleRenderer.RotationType Property
Cheers
Mike
