Hi guys 🙂I have created a File Geodatabase checkout from SDE, but when I open it using the File Geodatabase API, none of the tables are editable - even though only one of the tables has a geometry field in it.I have tried "replica access type" full and simple during checkout, with the same results. If I create the same File Geodatabase via ArcCatalog, the tables are editable when opened with the File Geodatabase API.Sample code:
           txtOutput.Text += "Opening File GDB...";
           try {
               // Open the geodatabase.
               mygdb = Geodatabase.Open("/path/to/file_gdb.gdb");
                              Â
               // Open the table.
               mytable = mygdb.OpenTable("\\users");
           } catch (Exception ex) {
               txtOutput.Text += "" + ex.Message.ToString();
               return;
           txtOutput.Text += "";
           if (mytable.IsEditable) {
               txtOutput.Text += "Editable";
           } else {
               txtOutput.Text += "NOT Editable";
Environment info:C# / VS2010 / .NET 4Product Name: ArcGIS Desktop 10Product Version: 10.0.3.3600ArcGIS Service Pack: 3 (build 10.0.3.3600)Any advice or information would be much appreciated. Please let me know if I can provide any more information.Warm regards,Patric
