Does AppStudio for ArcGIS integrate well with the Portal for ArcGIS server extension?
Hi Sowjanya,
Here is a blog post on how to configure and implement Portal for ArcGIS with AppStudio.
I hope this helps.
Nakul
Need more specifics but here is what is supported:
AppStudio version 1.2 (To be release soon, end of June 2016)
- You will be able to log into AppStudio using your portal credentials
- All your AppStudio apps will be stored in your portal
- AppStudio Player will work with your portal
- All templates will work with portal webmaps/maptours/feature services
In all versions of AppStudio:
Inside the app you can always consume resources coming from portal. There is a full fledged Portal object that supports query, authentication, credentials etc... that you can make use of in any appstudio app since its part of ArcGIS Runtime.
Sathya Prasad Can you point me to some documentation on how to leverage ArcGIS Portal maps in AppStudio?
Thnx
Thanks NManocha-esristaff
