Hi! How to select an object from a ready-made scene loaded from the portal, as in this example ! ArcGIS Runtime SDK for Android 100.4.1
Hi Alexander,
Is there a particular way you're wanting to select an object that is different from how it's demonstrated in the sample? Is it by tapping on it or as a result of some other query?
https://github.com/Esri/arcgis-runtime-samples-android/tree/master/java/scene-layer-selection/
Cheers,
Trevor
Clicking on it! I don't know how to work with: ArcGISSceneLayer sceneLayer = new ArcGISSceneLayer(buildings); The example uses a single layer that is loaded by url. How to do the same but with loaded from the scene portal
You should be able to access any scene layers in your scene with a call .getOperationalLayers() and then getting one or more layers from the LayerList. So something like:
for (Layer layer : scene.getOperationalLayers()) { if (layer instanceof ArcGISSceneLayer) { // follow the above sample for implementing identify and select on the scene layer } }
I was able to choose only one layer, how to implement for multiple layers?
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">final</SPAN> Layer Layer<SPAN class="operator token">:</SPAN> mSceneView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getScene</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">getOperationalLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>Layer <SPAN class="keyword token">instanceof</SPAN> <SPAN class="token class-name">ArcGISSceneLayer</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> sceneLayer <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>ArcGISSceneLayer<SPAN class="punctuation token">)</SPAN> Layer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> mSceneView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setOnTouchListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">DefaultSceneViewOnTouchListener</SPAN><SPAN class="punctuation token">(</SPAN>mSceneView<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> @Override <SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">boolean</SPAN> <SPAN class="token function">onSingleTapConfirmed</SPAN><SPAN class="punctuation token">(</SPAN>MotionEvent motionEvent<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// clear any previous selection</SPAN> sceneLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clearSelection</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> android<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN>Point screenPoint <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">android<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN>Point</SPAN><SPAN class="punctuation token">(</SPAN>Math<SPAN class="punctuation token">.</SPAN><SPAN class="token function">round</SPAN><SPAN class="punctuation token">(</SPAN>motionEvent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getX</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> Math<SPAN class="punctuation token">.</SPAN><SPAN class="token function">round</SPAN><SPAN class="punctuation token">(</SPAN>motionEvent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getY</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// identify clicked feature</SPAN> ListenableFuture<SPAN class="operator token"><</SPAN>IdentifyLayerResult<SPAN class="operator token">></SPAN> identify <SPAN class="operator token">=</SPAN> mSceneView <SPAN class="punctuation token">.</SPAN><SPAN class="token function">identifyLayerAsync</SPAN><SPAN class="punctuation token">(</SPAN>sceneLayer<SPAN class="punctuation token">,</SPAN> screenPoint<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">false</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> identify<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addDoneListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">try</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// get the identified result and check that it is a feature</SPAN> IdentifyLayerResult result <SPAN class="operator token">=</SPAN> identify<SPAN class="punctuation token">.</SPAN><SPAN class="token function">get</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> List<SPAN class="operator token"><</SPAN>GeoElement<SPAN class="operator token">></SPAN> geoElements <SPAN class="operator token">=</SPAN> result<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElements</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>geoElements<SPAN class="punctuation token">.</SPAN><SPAN class="token function">isEmpty</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> Log<SPAN class="punctuation token">.</SPAN><SPAN class="token function">d</SPAN><SPAN class="punctuation token">(</SPAN>TAG<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"geoelement not empty"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> GeoElement geoElement <SPAN class="operator token">=</SPAN> geoElements<SPAN class="punctuation token">.</SPAN><SPAN class="token function">get</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>geoElement <SPAN class="keyword token">instanceof</SPAN> <SPAN class="token class-name">Feature</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// select the feature</SPAN> sceneLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">selectFeature</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>Feature<SPAN class="punctuation token">)</SPAN> geoElement<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">InterruptedException</SPAN> <SPAN class="operator token">|</SPAN> ExecutionException e<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> String error <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Error while identifying layer result: "</SPAN> <SPAN class="operator token">+</SPAN> e<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getMessage</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> Log<SPAN class="punctuation token">.</SPAN><SPAN class="token function">e</SPAN><SPAN class="punctuation token">(</SPAN>TAG<SPAN class="punctuation token">,</SPAN> error<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> Toast<SPAN class="punctuation token">.</SPAN><SPAN class="token function">makeText</SPAN><SPAN class="punctuation token">(</SPAN>MainActivity<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> error<SPAN class="punctuation token">,</SPAN> Toast<SPAN class="punctuation token">.</SPAN>LENGTH_LONG<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="token boolean">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
