Hi,I try to use the Editor to edit my feature layer (already versioned), but when I run the website, all the Editor related button are greyed out. Is there any thing I did wrong? What I did is:1) Add an Editor to the Grid resources: <esri:Editor x:Key="EditWellPadPolygon" Map="{Binding ElementName=MyMap}" LayerIDs="WetlandsDelinationArea" GeometryServiceUrl="http://gis.ursbtr.com/ArcGIS/rest/services/Geometry/GeometryServer" />2) Add the Feature layer to the map layers:<esri:FeatureLayer ID="WetlandsDelinationArea" ProxyUrl="../proxy.ashx" Url="http://ourwebsite.com/ArcGIS/rest/services/Project/EcologyMobileProjects/FeatureServer/6" AutoSave="True" ValidateEdits="True" DisableClientCaching="True" Mode="OnDemand" Opacity="0.8" Visible="False" OutFields="*" InitializationFailed="MapServices_InitializationFailed"/>3) Add an editing panel with all the buttons: <StackPanel x:Name="editSP" Orientation="Vertical" VerticalAlignment="Stretch" DataContext="{StaticResource EditWellPadPolygon}"> <Button Command="{Binding Add}" Content="1. Add New Record" ToolTipService.ToolTip="" Margin="14,0,14,5"> <Button.CommandParameter> <sys:Int32>10101</sys:Int32> </Button.CommandParameter> </Button> <Grid > <Rectangle RadiusX="4" RadiusY="4" Margin="7,1,7,1" Stroke="Olive"></Rectangle> <StackPanel Orientation="Vertical" VerticalAlignment="Stretch"> <Button Command="{Binding Select}" CommandParameter="New" Content="2. Select a Record to Delete" Margin="14,8,14,8"/> <Button Command="{Binding ClearSelection}" Content="Clear Selection" Margin="28,2,14,8" Visibility="Collapsed"/> <Button Command="{Binding DeleteSelected}" Content="Delete Selected Record" Margin="28,2,14,8" Visibility="Collapsed"/> </StackPanel> </Grid> <Button Command="{Binding EditVertices}" Content="3. Change a Record Shape" Margin="14,5,14,5"/> </StackPanel>Thanks,Wei
