Oh yeah, that would make sense, wouldn't it? Thank you! I'm embarrassed I didn't think of that myself, as it seems so obvious now.The address locator I made from the parcel data worked well-- it mapped 72% of the points. The remaining points were not plotted largely because the parcel data is inaccurate, and it reports some addresses lumped together into one parcel with one address. For example, I need to map two addresses right next to each other (1100 and 1102). I believe that there are two addresses to this building because parcels recognizes the building as only having the address 1100, and therefore 1102 isn't being geocoded. Can you think of anything that I can do to fix this? My first intuition is that I should go into the parcel data and manually create the missing parcels. However, besides being time consuming to complete for 150 unmatched parcels, it will not be creating reliable or accurate data.Thanks again for the previous answer, and sorry to bombard you with an addition question!
