I just built one with all the address ranges set to 0 (zero). I can find intersections not problem using a table for the source as well as interactively.
Joe, I've also tryed what you suggested an it doesn't work , the locator works fine for searching streets by name, and if I look the properties I can see that the Suport intersections options is set to true, but when I search a street It always returns Address not found.
Does anyone else know a workaround?, the thing is that I won't have range info.
thanks for the info, even though it is discouraging
I was just reading this thread and searching the online help docs when Bruce posted his response.
Seems to me that the Street Name locator style is pretty limited in its use. The Dual Range style of locator does in fact support intersections; you might give this a try:
Add four 'phony' address range fields of numeric type to your reference data
LeftFrom LeftTo
RightFrom RightTo
Calculate all the values to 0 (zero)
Create a US Streets Dual Range locator referencing the data you just modified
Specify the intersection connectors of your choice
Build it and try it....
Hello
The US Street Name style does not support intersection geocodes.
Regards
I have the same problem, I'm using the "US Address - Street Name" Address Locator Style because the streets lines FC that I'm using has no information about nhouse numbers range at all, for that reason I wanted to use intersections.
Did anyone finally make this work? or is it a fact that this style doesn't support intersections?.
Any comments would be helpfull.
