Hi Robert,I am trying your eSearch widget (thanks!) and got the #1009 error as the result. It's the latest version 2.5.1.4, and I tried both the compiled and uncompiled ones, same result. I've read other similar questions but seems they all not fit my case. The key thing is I query the same map services with your previous widget, 2.4.0.12, with the same configuration xml and everything goes well as it should be. So seems the shapefield not revealed in the service doesn't hit my case. AlsoI tried to republish the mapservices as well but no help. Attached is the xml I used. Hope you can bring me some light. Thanks in advance. Best,AG
<relates> <relate> </relate> </relates>
<?xml version="1.0" ?> <!-- See Enhanced Search Widget XML Configuration.pdf for detailed explanation --> <configuration> <layers> <layer> <definitionexpression></definitionexpression> <enableexport>true</enableexport> <name>Boreholes</name> <url>http://hkgnts82/AGIS/rest/services/GISDB/Borehole/MapServer/1</url> <expressions> <expression alias="Borehole ID" textsearchlabel="Search Borehole ID [ Example: 27807 ]:"> upper(BH_ID) LIKE upper('%[value]%') </expression> <expression alias="Project Source" textsearchlabel="Search Zoning Code [ Example: KTE ]:" userlist="KTEr,SILw" > upper(Proj) = upper('[value]') </expression> </expressions> <graphicalsearchlabel>Use one of the graphical search tools to select Boreholes : </graphicalsearchlabel> <spatialsearchlayer>true</spatialsearchlayer> <titlefield>BH_ID</titlefield> <fields all="true" /> <links> <link includeinresults="false" field="" alias=""> <linkprefix></linkprefix> <linksuffix></linksuffix> <iconfield></iconfield> <iconprefix></iconprefix> <iconsuffix></iconsuffix> </link> </links> <zoomscale usegeometry="false">5000</zoomscale> </layer> </layers> <spatialrelationships> <!-- possible spatial relationships esriSpatialRelIntersects | esriSpatialRelContains | esriSpatialRelCrosses | esriSpatialRelEnvelopeIntersects | esriSpatialRelIndexIntersects | esriSpatialRelOverlaps | esriSpatialRelTouches | esriSpatialRelWithin currently unavailable: esriSpatialRelRelation --> <spatialrelationship> <name>esriSpatialRelContains</name> <label>entirely contained in</label> </spatialrelationship> <spatialrelationship> <name>esriSpatialRelIntersects</name> <label>interssected by</label> </spatialrelationship> <spatialrelationship> <name>esriSpatialRelEnvelopeIntersects</name> <label>intersected by envelop of</label> </spatialrelationship> </spatialrelationships> <bufferunits> <bufferunit> <name>UNIT_FOOT</name> <label>Feet</label> </bufferunit> <bufferunit> <name>UNIT_STATUTE_MILE</name> <label>Miles</label> </bufferunit> <bufferunit> <name>UNIT_METER</name> <label>Meters</label> </bufferunit> <bufferunit> <name>UNIT_KILOMETER</name> <label>Kilometers</label> </bufferunit> </bufferunits> <enabledatagridinteractionwithwidget>true</enabledatagridinteractionwithwidget> <toleranceforpointgraphicalselection>6</toleranceforpointgraphicalselection><!-- value is in screen pixels --> <tolerancebydefault>false</tolerancebydefault> <spatialreference>102003</spatialreference> <zoomscale>2400</zoomscale> <geometryservice>http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer</geometryservice> <csvseparator>,</csvseparator> <disablebuttons></disablebuttons><!--possible values one or more not all four search types comma separated text,graphic,spatial,grid,datagrid --> <defaultselectionoption>textInput</defaultselectionoption><!--possible values only one graphicalInput or textInput or spatialInput --> <enabledrawgraphicbutton>true</enabledrawgraphicbutton> <enablebuffergraphicbutton>true</enablebuffergraphicbutton> <selectedgraphicaltool></selectedgraphicaltool><!-- possible values are extent or polygon or mappoint or polyline or nothing --> <multipartgraphicsearch>true</multipartgraphicsearch> <floatorfixed>float</floatorfixed><!-- possible values are fixed and float --> <relatetooltip>Show Relates</relatetooltip> <relateicon>widgets/eSearch/assets/images/i_relate.png</relateicon> <labels> <bufferusergraphics>Buffer Graphic</bufferusergraphics> <norelatesfound>No related features found for: </norelatesfound> <norelatesfoundalerttitle>No Results</norelatesfoundalerttitle> <addtolerance>Add search tolerance to point selection</addtolerance> <existingdrawgraphicslabel>Use Existing eDraw Widget Graphics</existingdrawgraphicslabel> <existingbuffergraphicslabel>Use Existing Point Buffer Widget Graphics</existingbuffergraphicslabel> <graphicalsearchlabel>Graphical Search</graphicalsearchlabel> <textsearchlabel>Text Search</textsearchlabel> <resultslabel>Results</resultslabel> <layerlabel>Search Layer:</layerlabel> <layerfieldlabel>Search Layer Field:</layerfieldlabel> <nolayerlabel>No search layer defined.</nolayerlabel> <submitlabel>Search</submitlabel> <pointlabel>Select by Point</pointlabel> <linelabel>Select by Line</linelabel> <rectanglelabel>Select by Rectangle</rectanglelabel> <polygonlabel>Select by Polygon</polygonlabel> <clearlabel>Clear</clearlabel> <loadinglabel>Loading...</loadinglabel> <selectionlabel>Features Selected:</selectionlabel> <gridresultslabel>Show Results in Grid</gridresultslabel> <csvdefaultname>Selected Records</csvdefaultname> <relatescsvdefaultname>Related Records</relatescsvdefaultname> <exportbtnlabel>Export...</exportbtnlabel> <export2csvoptionlabel>Export to CSV...</export2csvoptionlabel> <export2txtoptionlabel>Export to Txt...</export2txtoptionlabel> <bufferlabel>apply a search distance:</bufferlabel> <spatialsearchlabel>Spatial search</spatialsearchlabel> <applybufferlabel>Apply buffer</applybufferlabel> <searchlayerlabel>Search entities of:</searchlayerlabel> <enablemultipartsearch>enable multi-part graphics</enablemultipartsearch> <zoomalllabel>Zoom</zoomalllabel> <zoomalltip>Zoom to all results</zoomalltip> <bufferalpha>Adjust buffer alpha</bufferalpha> <buffercolor>Select buffer color</buffercolor> </labels> <symbols> <simplefillsymbol color="0xff0000" alpha="0.5"> <outline color="0xff0000" alpha="0.8" width="2" /> </simplefillsymbol> <!-- You can have one or the other, either simplemarkersymbol or picturemarkersymbol defined for your point results NOT BOTH. picturemarkersymbol will override simplemarkersymbol if you do not have it commented out. --> <!--<simplemarkersymbol style="square" size="12" color="0xff0000" alpha="0.5" xoffset="0" yoffset="0" angle="0"> <outline style="solid" color="0x000000" alpha="1" width="1"/> </simplemarkersymbol> --> <picturemarkersymbol url="assets/images/i_search.png" height="30" width="30" xoffset="0" yoffset="0" /> <simplelinesymbol color="0xff0000" alpha="0.8" width="2" /> </symbols> </configuration>
