How do I set it up so that the baseMap is loaded from my local ArcGIS instance using the following.
var map = L.map('ui-map').setView([39, -97.5], 4); L.esri.basemapLayer('Streets').addTo(map);
What type of local layer are you trying to load as basemap? Tile layer, Vector Tile Layer, Map Image Layer, Image Service? Layers are stacked in the order you add them, so the first layer you load will be the basemap. You can use the dynamicMapLayer class to use a Map Image layer:
L<SPAN class="punctuation token">.</SPAN>esri<SPAN class="punctuation token">.</SPAN><SPAN class="token function">dynamicMapLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN><SPAN class="string token">'https://<myserver>/arcgis/rest/services/<map service>/MapServer'</SPAN><SPAN class="punctuation token">,</SPAN> layers<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>addToMap<SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Alternatively you could add a Tile Layer as basemap using the Leaflet base classes.
L<SPAN class="punctuation token">.</SPAN><SPAN class="token function">tileLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'http://{s}.tile.osm.org/{z}/{x}/{y}.png'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">addTo</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
A handy way of handling multiple basemaps and overlays is by using the Leaflet layer control:
<SPAN class="keyword token">var</SPAN> basemaps <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"Esri Topographic"</SPAN><SPAN class="punctuation token">:</SPAN> L<SPAN class="punctuation token">.</SPAN>esri<SPAN class="punctuation token">.</SPAN><SPAN class="token function">basemapLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Topographic'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"OSM"</SPAN><SPAN class="punctuation token">:</SPAN> L<SPAN class="punctuation token">.</SPAN><SPAN class="token function">tileLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'http://{s}.tile.osm.org/{z}/{x}/{y}.png'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">addTo</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> overlays <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"Streets"</SPAN><SPAN class="punctuation token">:</SPAN> L<SPAN class="punctuation token">.</SPAN>esri<SPAN class="punctuation token">.</SPAN><SPAN class="token function">dynamicMapLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN><SPAN class="string token">'https://<myserver>/arcgis/rest/services/<map service>/MapServer'</SPAN><SPAN class="punctuation token">,</SPAN> layers<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Towns"</SPAN><SPAN class="punctuation token">:</SPAN> L<SPAN class="punctuation token">.</SPAN>esri<SPAN class="punctuation token">.</SPAN><SPAN class="token function">dynamicMapLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN><SPAN class="string token">'https://<myserver>/arcgis/rest/services/<map service>/MapServer'</SPAN><SPAN class="punctuation token">,</SPAN> layers<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> L<SPAN class="punctuation token">.</SPAN>control<SPAN class="punctuation token">.</SPAN><SPAN class="token function">layers</SPAN><SPAN class="punctuation token">(</SPAN>basemaps<SPAN class="punctuation token">,</SPAN> overlays<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">addTo</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
