I used formatting in webmap, Smart Editor Json configuration . But it still showing with comma for integer and double field type values .
Resolved with small code changes
I am have the same issue. What code change did you make and where can i find it?
Hi Vijay,
I hope all is well. Would you be able to upload screen shots of the changes you made so that I may do the same?
Thank you.
Best,
Heath
IN showFeature function, Please add Highlighted In Bold below accordingly
_showFeature: function(b, c) { n.forEach(d.fieldInfos, function(a) { m = a.field; if ((a.type.indexOf("Integer") != -1) || ((a.type.indexOf("Double") != -1) && (a.name=="ID" ))) { if (a.dijit) a.dijit.constraints && (a.dijit.constraints.pattern = '#');
Thank you for your response. I assume this is the Widget.js file? What version of WAB are you using? Again thank you
This is what I was able to find in the Widget.js
_showFeature: function (b, c) { if (b) { this._currentFeature = b; c = c ? c : b.getLayer(); var e = c.getEditCapabilities({ feature: b, userId: this._userIds[c.id] }); this._canUpdate = e.canUpdate; this._canDelete = e.canDelete; if (e = this._getLInfoFromFeatureLayer(c)) { this._setCurrentLInfo(e); var g = b.attributes, k = this._findFirst(e.types, "id", g[e.typeIdField]), f = null; n.forEach(e.fieldInfos, function (b) { f = b.field; var c = []; b.dijit && 1 < b.dijit.length ? n.forEach(b.dijit, function (a) { c.push(a) }) : c.push(b.dijit); n.forEach(c, p.hitch(this, function (b) { if (b) { var c = this._setFieldDomain(b, k, f), e = g[f.name], e = e && c && c.codedValues && c.codedValues.length ? c.codedValues ? c.codedValues.name : e : e; a.isDefined(e) || (e = ""); "dijit.form.DateTextBox" === b.declaredClass || "dijit.form.TimeTextBox" === b.declaredClass ? e = "" === e ? null : new Date(e) : "dijit.form.FilteringSelect" === b.declaredClass && (b._lastValueReported = null, e = g[f.name] + ""); try { this._setValue(b, e), "dijit.form.FilteringSelect" === b.declaredClass && !1 === b.isValid() && this._setValue(b, null) } catch (la) { b.set("displayedValue", this.NLS_errorInvalid, !1) } } })) }, this); this._attachmentEditor && e.showAttachments && this._attachmentEditor.showAttachments(this._currentFeature, c); (b = c.getEditSummary(b)) ? (this.editorTrackingInfoDiv.innerHTML = b, d.show(this.editorTrackingInfoDiv)) : d.hide(this.editorTrackingInfoDiv) } } },
I was unable to locate
What version of WAB are you using. I am using 2.8 through Portal.
Thank you,
_showFeature: function (b, c) { if (b) { this._currentFeature = b; c = c ? c : b.getLayer(); var e = c.getEditCapabilities({ feature: b, userId: this._userIds[c.id] }); this._canUpdate = e.canUpdate; this._canDelete = e.canDelete; if (e = this._getLInfoFromFeatureLayer(c)) { this._setCurrentLInfo(e); var g = b.attributes, k = this._findFirst(e.types, "id", g[e.typeIdField]), f = null; n.forEach(e.fieldInfos, function (b) { f = b.field; var c = []; b.dijit && 1 < b.dijit.length ? n.forEach(b.dijit, function (a) { c.push(a) }) : c.push(b.dijit); n.forEach(c, p.hitch(this, function (b) { if (b) { var c = this._setFieldDomain(b, k, f), e = g[f.name], e = e && c && c.codedValues && c.codedValues.length ? c.codedValues ? c.codedValues.name : e : e; a.isDefined(e) || (e = ""); "dijit.form.DateTextBox" === b.declaredClass || "dijit.form.TimeTextBox" === b.declaredClass ? e = "" === e ? null : new Date(e) : "dijit.form.FilteringSelect" === b.declaredClass && (b._lastValueReported = null, e = g[f.name] + ""); try { this._setValue(b, e), "dijit.form.FilteringSelect" === b.declaredClass && !1 === b.isValid() && this._setValue(b, null) } catch (la) { b.set("displayedValue", this.NLS_errorInvalid, !1) } } })) }, this); this._attachmentEditor && e.showAttachments && this._attachmentEditor.showAttachments(this._currentFeature, c); (b = c.getEditSummary(b)) ? (this.editorTrackingInfoDiv.innerHTML = b, d.show(this.editorTrackingInfoDiv)) : d.hide(this.editorTrackingInfoDiv) } }},
You can add the code in Highlighted in bold
@vijaybadugu This issue should now be resolved in the latest updates of the Smart Editor in ArcGIS Online. The Smart Editor Widget: Two Years in Review - Esri Community
