Thanks for the offers of help. I did attempt to create an altname table and I thought I had it figured out to some extent, but it fails when it tries to create the locator.I have a centerlines file with a streets with many segments. I created a JOINID field on each segment. For example, segment JOINID 36 is called FAYETTEVILLE RD, but it's also known as US 401 HWY.So I have a matching ALTNAME table with JOINID 36 and it's street name is US 401.STREET_ID DIR_PRE STNAME STYPE DIR_SUF joinid465 US 401 HWY 36The ALTNAMES table I'm creating is a DBF file. The centerlines file table I used was also a DBF table. Is that what I should be doing?
Your streets need to be in the form of a feature class, not a file. When you geocode, you are turning an address that you and I recognize into a pair of X,Y coordinates that the GIS recognizes; the coordinate system of your street feature class is the basis of those x-y pairs.
I'm not familiar with geodatabases and feature classes yet. I have worked almost exclusively in shapefiles. I see a tool for featureclass to shapefile, but not the other way around.I opened the centerlines shapefile dbf table and added the JOINID field. I was not working with just a dbf of street names, if that matters.I felt like I was following all the steps, but when it tries to build the locator, it would fail with a very general error.
