Hi
I'm setting up our version 2 Open Data site and I'm having an issue where a dataset is showing up twice in the datasets list.
https://newversion-marlborough.opendata.arcgis.com/datasets?q=total%20control&sort=name
Both results point at the same ArcGIS Online item https://www.arcgis.com/home/item.html?id=a56ff59d1f8645e188b052f0e96e3789
I've tried unsharing and resharing it again, and reindexing. What else could I try?
Malcolm
Hi Bhanu,
We'll remove the extra dataset.
Courtney
That dataset is showing up twice again!
Both looking at the same item
http://marlborough.maps.arcgis.com/home/item.html?id=a56ff59d1f8645e188b052f0e96e3789
I do recall what change I made this time though, about a week ago I updated the Access and Use Constraints section in the ArcGIS Online item
Hello Courtney, thanks for your reply !!
Here is the link for the datasets
http://data-airdrie.opendata.arcgis.com/datasets?t=Imagery
The datasets are a document link to the dropbox to download the files.
The dataset for year 2015 is appearing twice ,where the second one with no thumbnail does not exist.
Any insight will be very much appreciated.
I think I did change the service URL for that dataset. I've done that before and usually I unshare the dataset, change the URL and then share it again and re-index etc.
Would it be better to avoid doing that and create a new item instead and then delete the old one?
Can you please provide the URLs of the duplicate datasets, if you still see them on your site?
Thanks -
We did remove them from the database. This has happened in the past when the ArcGIS Online item's underlying service URL is changed; that bug might have popped up again. Is there anything you recall doing that's out of the ordinary workflow?
I have had that happen before and I was flummoxed and tried all of things you did (sharing/unsharing/re-indexing), and I went home (end of day) and came back the next morning and the extra instance of the dataset was gone. I think there was probably just a lag somewhere a behind the scenes process and all I had to do was wait it out.
Looks like its been fixed (not sure if it was something you did or not though!)
Is there a way to avoid this occuring or is there anything I might have done to make it show up twice?
I too am experiencing the same issue with our organizations open data site.
Just as Malcom mentioned ,I have tried resharing it refreshing the index ..but no luck !!
Thanks Courtney
Hi Malcolm,
We're taking a look. I'll update here soon.
