<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" /> <title>Topographic Map</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/claro/claro.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } .esriScalebar { padding: 20px 20px; } #map { padding:0; } </style> <script type="text/javascript"> var djConfig = { parseOnLoad: true }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script> <script type="text/javascript"> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("dijit.form.ComboBox"); var map; function init() { var initExtent = new esri.geometry.Extent({ "xmin": -122.46, "ymin": 37.73, "xmax": -122.36, "ymax": 37.77, "spatialReference": { "wkid": 4326 } }); map = new esri.Map("map", { extent: esri.geometry.geographicToWebMercator(initExtent) }); //Add the topographic layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); dojo.connect(map, 'onLoad', function (theMap) { //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map, map.resize); }); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width: 100%; height: 100%; margin: 0;"> <div id='lp' dojotype='dijit.layout.ContentPane' region='left' style='width:300px;'> <select id="boroughSelect" dojotype="dijit.form.ComboBox" autoComplete="true" forceValidOption="false" onchange="executeMenuQuery(this)"> <option>Manhattan</option> <option>Brooklyn</option> <option>Bronx</option> <option>Staten Island</option> <option>Queens</option> </select> </div> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;"></div> </div> </body> </html>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dojox/grid/resources/Grid.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dojox/grid/resources/claroGrid.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dojox/image/resources/image.css">
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" /> <title>Topographic Map</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/claro/claro.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } .esriScalebar { padding: 20px 20px; } #map { padding:0; } </style> <script type="text/javascript"> var djConfig = { parseOnLoad: true }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script> <script type="text/javascript"> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("dijit.form.ComboBox"); dojo.require("dijit.layout.AccordionContainer"); var map; function init() { var initExtent = new esri.geometry.Extent({ "xmin": -122.46, "ymin": 37.73, "xmax": -122.36, "ymax": 37.77, "spatialReference": { "wkid": 4326 } }); map = new esri.Map("map", { extent: esri.geometry.geographicToWebMercator(initExtent) }); //Add the topographic layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); dojo.connect(map, 'onLoad', function (theMap) { //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map, map.resize); }); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width: 100%; height: 100%; margin: 0;"> <div id='lp' dojotype='dijit.layout.AccordionContainer' region='left' style='width:300px;'> <div dojotype='dijit.layout.ContentPane' title='pane1'> Content for Pane 1 </div> <div dojotype='dijit.layout.ContentPane' title='pane 2'> <select id="boroughSelect" dojotype="dijit.form.ComboBox" autoComplete="true" forceValidOption="false" onchange="executeMenuQuery(this)"> <option>Manhattan</option> <option>Brooklyn</option> <option>Bronx</option> <option>Staten Island</option> <option>Queens</option> </select> </div> </div> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;"></div> </div> </body> </html>
Thanks, I found the source of the error, it was in the css.I need to change your code to version 2.1 for the map to load properly. Do I need to install an update or do something else so that I can use the 3.1 API?Thanks for your help, Jason
So are you saying I cannot run the examples given by ESRI using Aptana or Notepad++ unless through a web server?In either case, I have been having trouble using 3.1 running from both localhost (through MVC) and running as a file from an editor. For the most part 2.1 has worked, but now I am having trouble using the locator class (as given in the ESRI example http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm).
