This is actually a windows display setting I bet your device has its setting at 125% if you change it to 100% this will resolve the issue. There was a post about this a few months ago when I had the same issue. If you go to control panel>display and change the setting to 100% this should resolve the issue.
What version of Win Mobile is this? There was a bug logged for 10.1.1- (NIM089287-Data collected in ArcGIS for Windows Mobile v10.1.1 produces a datum shift of between 4-5 feet.)NIM089287 is fixed in ArcGIS Desktop and ArcGIS Server 10.2.1 update which includes solution to datum transformation method selection between WGS84 and map spatial reference. Users can specify the transformation method between WGS84 and map spatial reference for ArcGIS for Windows Mobile application to use. It it is not specified by the user, the application will be based on map spatial reference appliable are and choose suitable datum transformation method.
Hi Christopher,
Can you please explain how - using the NIM089287 fix - can user specify the transformation method? Is it defined in the ArcGIS Server mobile service or in the Mobile Project Centre?
Martin
