Insight on what scenarios would require one to unregister the web adaptor? I can't seem to find much on this action.
We are having issues installing the 10.3 version.
What are the issues you are experiencing Collin? When you un-install the web adaptor from the system, did you verify that the directory created from the web adaptor was removed before installing the new one? Are you installing as an administrator on the web server machine?
Hi Dennis,
We uninstalled the 10.1 adaptor, deleted the virtual directory from our website in IIS and then I renamed the web adaptor folder but left it in the website directory. Figured it was best to leave it but rename it in case it was needed to fall back on or use for troubleshooting.
When we uninstall the 10.3 after an unsuccessful attempt, we then delete the ArcGIS web adaptor virtual directory from our IIS site so that when we reinstall allowing us to use the same web adaptor name. We are then deleting the directory that is created on installation in our website directory. So what's left? But clearly we are missing something.
I am installing under my account which is an admin. and the installation is on the web server, which in this case is our dev env so the GIS server and SQL are both on the same machine.
Our in house developer reports that he does not think the request is even making it to IIS as he can't find even a failed request entry.
Does this call for the un-registration of the web adaptor perhaps?
From my recent experience in ArcGIS Server 10.6.1, this is still an issue.
Meaning, I uninstalled Web Adaptor per ArcGIS documentation...that is all it says to do. I then restarted ArcGIS Server and then restarted the server machine. Then I checked ArcGIS Server Manager, Site tab, and it still had the Web Adaptor listed as registered. So I went into ArcGIS Server Admin and unregistered it there per the instructions in the reply above. It worked - cleared the Web Adaptor registration from Manager.
Unless I am missing something, would it not be helpful to include those instructions in the online ArcGIS documentation that covers Uninstalling Web Adaptor so it is all in one handy location?
