I have two features class (multipolygon and multiline) with ST_GEOMETRY format in a 9.3 geodatabase.
How to detect features that contains arcs using sde ?
OK, I will try using ArcObjects and ComTypes.
But how to test an ArcObject IGeometry (polyline or polygon) contains arcs ?
I didn't realize your client was also stuck back at 9.3.x. Do you have access to a newer client that can connect to the 9.3 geodatabase?
If you have to stick with ArcGIS 9.3.1 as a client, I will have to think about options. It may be you could use comtypes or a similar package to access ArcObjects directly from Python.
I'm under ArcGIS 9.3.1, so I tried using ArcgisScripting.
But Geometry object seems not to have ".JSON" property.
I am not sure of an SQL-based approach, but you can use an ArcPy search cursor:
fc <SPAN class="operator token">=</SPAN> <SPAN class="comment token"># path to feature class</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"OID@"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"SHAPE@"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cur<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> oid<SPAN class="punctuation token">,</SPAN> shape <SPAN class="keyword token">in</SPAN> cur<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="string token">"curve"</SPAN> <SPAN class="keyword token">in</SPAN> shape<SPAN class="punctuation token">.</SPAN>JSON<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> oid<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
