I am trying to use "accordion" using Calcite Maps bootstrap (jQuery version). I took a code from this link and used in my HTML file, but it didn't work for some reasons. I am not sure the problem is because of how I implemented the accordion code or something else. Either the case, are there any ways to make the accordion to work? I would very much appreciate your help.
Here is the video for the problem: calcite-maps-accordion and below is the code I used in the application.
<SPAN class="selector token">.areaInfo-accordion</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">margin-top</SPAN><SPAN class="punctuation token">:</SPAN> 80px<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">margin-left</SPAN><SPAN class="punctuation token">:</SPAN> 200px<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN> 700px<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 27%<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">overflow</SPAN><SPAN class="punctuation token">:</SPAN> auto<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> none<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">float</SPAN><SPAN class="punctuation token">:</SPAN> left<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">z-index</SPAN><SPAN class="punctuation token">:</SPAN> 2<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN><SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"areaInfoA"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"areaInfo-accordion"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>aside <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"js-accordion accordion"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"accordion-section is-active"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>h4 <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"accordion-title"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>span <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"accordion-icon"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>svg xmlns<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.w3.org%2F2000%2Fsvg" target="_blank">http://www.w3.org/2000/svg</A><SPAN>"</SPAN></SPAN> width<SPAN class="operator token">=</SPAN><SPAN class="string token">"14"</SPAN> height<SPAN class="operator token">=</SPAN><SPAN class="string token">"14"</SPAN> viewBox<SPAN class="operator token">=</SPAN><SPAN class="string token">"0 0 32 32"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"svg-icon"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN>path d<SPAN class="operator token">=</SPAN><SPAN class="string token">"M28 9v5L16 26 4 14V9l12 12L28 9z"</SPAN><SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>svg<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN>
Title <SPAN class="keyword token">of</SPAN> Section
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>h4<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"accordion-content"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>p<SPAN class="operator token">></SPAN>Stuff<SPAN class="operator token">!</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>p<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"accordion-section"</SPAN><SPAN class="operator token">></SPAN>
Title <SPAN class="keyword token">of</SPAN> Second Section
Title <SPAN class="keyword token">of</SPAN> Third Section
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>aside<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
