I'm new to working with esri and I am struggling a bit with mapping polygons. All of the examples are far more complex than I need at the moment. I thought I would start by trying to map a single boundary from my data set which I have included in the JSFiddle below. I seem to be missing a step somewhere as the shape does not appear on the map. Can someone please take a look and post back a functional version of this code? I think it will make sense to me once I see some simple functional code. Thanks!
Edit fiddle - JSFiddle
Andrew,
So using the polygon coordinate from your 4326 Lat Lon Fiddle here is all the JS corrections to make you app work.
Your issues:
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta http<SPAN class="operator token">-</SPAN>equiv<SPAN class="operator token">=</SPAN><SPAN class="string token">"content-type"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/html; charset=UTF-8"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> type<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/css"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.18%2Fesri%2Fcss%2Fesri.css" target="_blank">https://js.arcgis.com/3.18/esri/css/esri.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.18%2Fdijit%2Fthemes%2Ftundra%2Ftundra.css" target="_blank">https://js.arcgis.com/3.18/dijit/themes/tundra/tundra.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script type<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/javascript"</SPAN> src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.18%2F" target="_blank">https://js.arcgis.com/3.18/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style type<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/css"</SPAN><SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body<SPAN class="punctuation token">,</SPAN> #map <SPAN class="punctuation token">{</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script type<SPAN class="operator token">=</SPAN><SPAN class="string token">'text/javascript'</SPAN><SPAN class="operator token">></SPAN> <SPAN class="keyword token">var</SPAN> map<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> poly<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> rings <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.84643929747681</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.794747499777252</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.84746944059417</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.777777585460555</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.84722308493257</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.777765081563238</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.84734540274029</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.77617950435792</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.839087246083</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.776067995928258</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83907815798979</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.777678497549928</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83416432833802</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.777613405008282</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83423339873944</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.774308267743493</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83627435094607</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.774331258087088</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83650250420743</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.768739904101523</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83434976877875</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.768711424486327</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83449674865503</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.759535898715534</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83153767163584</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.759454674692073</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.8315677943355</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.758526742051714</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83005910082632</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.758508829782208</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83006868956933</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.758786174224618</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.82900446855203</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.758908246313581</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.8289949753526</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.759385682551219</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.82487316219854</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.759248721473909</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.82484602484318</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.75872651380071</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.82412031298628</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.758699296726014</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.82408175711976</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.759352576430167</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.82157828434823</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.759339882469213</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80856646658245</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.759080021683424</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80888335765516</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.758450907732829</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.79995750845733</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.758533218450872</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.79997094742524</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.759712134102493</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.79943687524859</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.7597149508701</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.79943670060027</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.760282389603589</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.794542463224</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.760329851277262</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.79455678654557</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.762173473662926</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78013221695674</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.762213781174466</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78011696035968</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.758570573926249</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78495497954226</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.758559238277535</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78482197208915</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.7440868600572</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78156279026786</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.7440874593831</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78155632116017</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.742859852735791</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78020013424161</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.742692533027387</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78014870144392</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.740331252611682</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78496129064149</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.740319191050837</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78493577681539</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.741680319679745</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78970647436134</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.74167645161603</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78967003464045</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.736739076030581</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78863710553577</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.73674166684853</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.79046584125427</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.731520359958182</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78882018631835</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.731754142022737</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78486131889905</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.73171369944793</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.78499946200444</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.72597439833222</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.79443348172011</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.725930276684629</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.79442818142205</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.718960693687741</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80329766254188</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.718942265098015</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80349393133687</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.719353413765987</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80335524844719</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.719608380997776</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80024649454289</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.719618364056387</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80028472026963</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.722408467878054</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80404656373796</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.722312852462288</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.8040572551968</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.72288111942806</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80383873196455</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.723000640046038</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80378996681196</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.723428813694241</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80406543031074</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.723440396945627</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80426954555739</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.728335171540131</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80516834834002</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.728386521609465</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80536162726462</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.728169899967561</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80645891488531</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.729382651139673</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80488862337847</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.729383753933163</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80488383474777</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.729096464470821</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80350585656187</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.72909169756678</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80350720905331</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.729586171914292</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80429714973558</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.729584248024857</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80429780172038</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.729443734409053</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80900365606557</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.72942330792354</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.80907020278781</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.728881519276776</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.81005415995379</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.7282449980952</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.81096223382573</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.728172841697329</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.8109733064102</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.728001630720307</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.81174417257014</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.727918727365854</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.8126396280047</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.727895284611236</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.814072155668</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.72822290649885</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.81407338367458</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.728320173289752</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.81634435967105</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.728393230567228</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.81692316932451</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.72786130732181</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.81854163028665</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.7275849837872</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.81969445009173</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.725864536703185</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.82079713040415</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.725688234486974</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.82155833637722</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.725133367924336</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.823162513576</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.724686849288709</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.82391630308972</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.724683248188327</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.82578374857987</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.725081462220516</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.82931770552543</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.724365174264683</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83051245519115</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.724340332476181</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83096484492604</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.72417943944739</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83155835254186</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.723121327706387</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83201579988659</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.722700992509921</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83502483244909</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.721013771929435</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83508500339671</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.719347040232854</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83253015965342</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.719332253159514</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83227326858214</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.718429811344905</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83254247781764</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.71739926163977</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83260827781926</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.710295858947326</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83478913335613</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.710325972300495</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83478493723744</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.709444216231333</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.836251385195</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.70944436217718</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83625039266759</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.709275037551791</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83653645377645</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.709273856139227</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83651735655155</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.709840536269006</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83711834098233</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.709838861839778</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83711729617531</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.709480390352958</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83773390177758</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.709478598910934</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83778629427623</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.706477980273959</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83977589449138</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.706506691335896</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.83987886924838</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.702782436899312</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.84226919044649</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.702857714186727</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.84480411467787</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.702594115473161</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.84480888780975</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.702775121508743</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.84590517805539</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.702696802006152</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.84925088602314</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.703311623388011</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.84890746584777</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.700229255998273</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85017470573862</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.701727663173713</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85227088182913</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.703193790640192</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85631157482817</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.700200442033541</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85586501070188</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.700148825974686</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86029166612506</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.697196595792526</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86033799715389</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.6927377696836</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86217642733084</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.692725793007938</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86220288082239</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.695876253389763</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86415204273882</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.694433998822262</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86485687490452</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.694570106859189</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86503494908821</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.695752289933083</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86592832952374</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.696504853830888</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86704534771431</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.696458601889873</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86719413941714</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.697425734230166</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.8675732790318</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.697468808323954</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86812795383014</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.697249351567812</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86938739666191</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.697247936634476</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87055380989079</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.696764436258071</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87190573287103</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.696759591010164</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87196451229596</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.700132274091416</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86947452569156</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.700147538047823</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86953838394085</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.705154954890567</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86891555849039</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.705227218655033</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86842979454</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.706017202722727</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86712443038236</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.707086284606682</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86653121366899</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.707216857587809</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86599135538646</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.7076514622743</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86592190473364</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.708029379254889</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86514543962929</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.707940654130304</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86294295667254</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.7062882161696</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86138607655876</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.706261166947122</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86061586451795</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.706098506761521</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86062998214834</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.708238466596171</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86032251278506</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.710059283683023</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86013553423899</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.718213819252959</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86268318966705</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.71823345068394</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86262857499938</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.720711683783144</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86495281212049</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.720738345910213</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86508716895837</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.715697021883315</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86783493738957</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.71567630247344</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86782847967389</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.715196278397094</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87010384360964</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.715179071550445</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87006965051056</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.71656550683236</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87028731217909</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.716571064111378</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87025170385739</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.716872167348761</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87550529718345</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.716800734791882</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87534820633488</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.720992883039251</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87131179870531</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.720951505443082</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87126439488723</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.722782084123708</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86503705071203</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.722716546680154</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86496341930247</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.724577043052157</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87479846329738</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.724602564543524</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87480860640557</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.726413790565637</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87997249877789</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.726408586114815</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87974833806437</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.735974801640936</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.88812183422586</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.736098628506788</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.90185724691345</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.739311600529206</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.90189166495085</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.749590952275106</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87913406682009</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.749654755555639</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87924927562493</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.7440830792096</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87415195616141</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.743514905458582</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.87409366860528</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.745158216426631</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86906228629245</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.74511261914121</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86898528255442</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.746893875180561</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86398470557552</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.746823504019538</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86397525572546</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.752487141292875</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86154991795748</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.752451312317092</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86142968905345</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.758122079882455</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86389568836252</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.758124279561386</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.8638477839974</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.760741152556022</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86557911564854</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.761745904176479</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86656581034897</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.761764586145532</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86650659254073</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.767108838611215</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86346941962945</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.7670641539955</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86351632171983</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.765447960326831</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85616957707562</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.765468719187155</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85612165204755</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.768198172918233</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85835004088104</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.768216672389755</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85831146084749</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.769113148773855</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85373183223192</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.769070713378419</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85359558677827</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.777850760861106</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85632771092052</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.777901582518965</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85593279735606</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.783403236910395</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86106280952092</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.783491897044875</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86106826980235</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.783360355485875</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86586251539458</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.781568876904615</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86718183785997</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.783834967007735</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86778236674188</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.78383763773202</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86777508439702</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.784011525719237</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86590151457385</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.784020259025311</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86243588129518</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.7852883793627</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86247512499997</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.78767761199137</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86736707597623</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.789899705995623</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86728782276052</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.792055650584111</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86424907904173</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.792071347001063</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86424551647148</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.791895739671617</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86343275896253</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.791240746527215</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86249861094632</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.791225246847475</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.86248811510116</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.79062186464634</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85665682429489</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.787892278364545</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85519648447419</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.787942789419695</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85068480739257</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.78959122276018</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.85042291681486</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.797338628268818</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.84628723651744</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.797351337402979</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.84643929747681</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">41.794747499777252</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Polygon"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/graphic"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN> Map<SPAN class="punctuation token">,</SPAN> Polygon<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> SimpleFillSymbol <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"topo"</SPAN><SPAN class="punctuation token">,</SPAN> center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.09</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">39.32</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">7</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> polygonJSON <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"rings"</SPAN><SPAN class="punctuation token">:</SPAN> rings<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"spatialReference"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"wkid"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> poly <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Polygon</SPAN><SPAN class="punctuation token">(</SPAN>polygonJSON<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> map<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN>poly<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"tundra"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks guys, I really appreciate the help!
so much for assuming it was just drawing somewhere else on screen grief!
Here is a link to the ABCs of AMD:
The abc’s of AMD | ArcGIS Blog
I'm able to take a google maps example of mapping a simple polygon and swap out the lat lng boundary coordinates and produce a hello world like this Edit fiddle - JSFiddle in about 10 minutes.
I've spent far too much time trying to track down the equivalent example in Esri without luck and so far failed to produce a hello world of drawing a simple polygon. Is it just me or have other people experienced this frustration getting started with Esri?
It has these suggestions:
Popular wkid'sWeb Mercator 3857Latitude/Longitude (WGS84) 4326
Is one of of those preferable over the other?
Here is a fiddle for 4326 Latitude/Longitude (WGS84) Edit fiddle - JSFiddle
Here is one for Web Mercator 3857 Edit fiddle - JSFiddle
What I really need is a functional fiddle demonstrating how to get a boundary to display. Thanks!
from your first link
Searching API Methods ... under spatial reference
The spatial reference for the output and input geometries. The output and input spatial references must match.
Choose any of the wkid's from the Geographic Coordinate System wkid reference or Projected Coordinate System
wkid reference. 26912 is the default.
The default is probably not what you want.
I would check the spatial references of the destination map... perhaps it is in web mercator, which means you would want your input coordinates to match those.
The geometry originated from this system AGRC Developer Web API and my example is using the first result from here. The end goal is to store that geometry in my own database and to be able to map applicable boundaries as needed in my web application. I'm not sure what type of coordinates those are so hopefully those links can provide you with more information. Looking for any suggestions anyone has on how to work with this data set.
are those UTM or other projected coordinates? Does the basemap use web mercator for its projection? If so, they won't align unless there is some projection-on-the-fly ability
