Hi Tim,
I was wondering if you ever figured out a solution for this? I am currently trying to import a XML workspace document into a 10.2 SDE Geodatabase. I am getting this error " Fata Error parsing xml. LIne - 16337, char =0 Reason: unexpected end of input."
I am exporting from 9.3.1 to 10.2.
Michelle
Does simple copy\paste or Export\Import work for the same data?
Try exporting the xml under a different name from the original feature class and run the import again. This issue could be related to a possible metadata corruption during the first export.
