import arcpy from numpy import * # based on blog post: # http://shreshai.blogspot.nl/2011/07/utilizing-numpy-to-perform-complex-gis.html # input and output rasters inputDEM = r'C:\Project\_Forums\numpy\grd\dem' outRasE1 = r'C:\Project\_Forums\numpy\grd\dem01E1' outRasE2 = r'C:\Project\_Forums\numpy\grd\dem01E2' outRasAlt = r'C:\Project\_Forums\numpy\grd\dem01alt' # determine dimensions of array myArray = arcpy.RasterToNumPyArray(inputDEM) [rows,cols]= myArray.shape # cellsize = 10m, distance of 200m = 20, window size will be 41 # half the window size (20 = 20 pixels * 10m/pixel = 200 meters, moving window = 420 * 420) winhalf = 20 # provide value in case of division by zero infE1 = (winhalf * 2 + 1)^2 infE2 = (winhalf * 2 + 1)^2 * myArray.max() IE1=zeros((cols,rows)) IE2=zeros((cols,rows)) Ialt=zeros((cols,rows)) cnt = 0 for r in range(0,rows): if r % 10 == 0: print "Processing row:{0}".format(r) for c in range (1,cols): cnt+=1 value = myArray[r,c] r1 = r - winhalf if r1 < 0: r1 = 0 r2 = r + winhalf if r2 > rows: r2=rows c1 = c - winhalf if c1 < 1: c1 = 1 c2 = c + winhalf if c2 > cols: c2 = cols # size is number of pixels in moving window size = (r2-r1+1) * (c2-c1+1) # E1= (# cells in surrounding area with elev.< cell elev.)/(# cells in surrounding area with elev.> cell elev.) data = myArray[r1:r2+1,c1:c2+1] indicesGT = where(data>value,ones(data.shape),zeros(data.shape)) indicesLT = where(data<value,ones(data.shape),zeros(data.shape)) outGT = sum(indicesGT) outLT = sum(indicesLT) if outGT == 0: outValE1 = infE1 else: outValE1 = outLT / outGT # E2= (sum[cell elev.-(elev.of surrounding cells<gage elev.)])/(sum[(elev.of surrounding cells>cell elev.)-cell elev.]) indicesGTE2 = where(data>value,data - (ones(data.shape)*value),zeros(data.shape)) indicesLTE2 = where(data<value,(ones(data.shape)*value) - data,zeros(data.shape)) outGTE2 = sum(indicesGTE2) outLTE2 = sum(indicesLTE2) if outGTE2 == 0: outValE2 = infE2 else: outValE2 = outLTE2 / outGTE2 # alternative output value could be: # percentage of pixels in neighborhood with value higher than pixel value indices = where(data>value,ones(data.shape),zeros(data.shape)) outVal = sum(indices) outPerc = outVal * 100 / size # assign values to output array IE1[c,r] = outValE1 # E1 IE2[c,r] = outValE2 # E2 Ialt[c,r] = outPerc # transpose I2E1 = IE1.transpose() I2E2 = IE2.transpose() I2Alt = Ialt.transpose() # retrieve meta from input raster descData=arcpy.Describe(inputDEM) cellSize=descData.meanCellHeight extent=descData.Extent spatialReference=descData.spatialReference pnt=arcpy.Point(extent.XMin,extent.YMin) #E1 newRasterE1 = arcpy.NumPyArrayToRaster(I2E1,pnt, cellSize,cellSize) newRasterE1.save(outRasE1) #E2 newRasterE2 = arcpy.NumPyArrayToRaster(I2E2,pnt, cellSize,cellSize) newRasterE2.save(outRasE2) #Alternative newRasterAlt = arcpy.NumPyArrayToRaster(I2Alt,pnt, cellSize,cellSize) newRasterAlt.save(outRasAlt) print "ready..."
Xander,Wow, thank you so much for putting so much time into this. I am incredibly impressed.-spencer
Hello. I was wondering if I could get a bit of help with this code?I've been trying to run it in PyScripter.I'm getting the following error message: TypeError: unsupported operand type(s) for ^: 'int' and 'numpy.float64'
