I list the server in browse as D422453603 and get an error that that there is NO service running on this server.
2) Do I need to populate the C:\Inetpub\wwwroot directory with a clientacesspolicy.xml file & if I do?...do I add D422453603 to this file...and where?
3) or do I need to go through the Proxy setup within the Viewer?
You must give the REST services end point Url, something like http://D422453603/ArcGIS/rest/services. If not working in the viewer, try the Url directly in your browser, you should get the list of services.If still not working it's an issue with your server.You don't need that as long as your application server is the same one as your arcgis server, but you may need it in your future production environment.It's an alternative if you can't add the clientaccesspolicy to the ArcGIS server(for example with external servers)
...I do not need the clientaccesspolicy.xml yet...but when I do what lines in that file need editing and how might that look?
Also, how would I do I add a Basemap from an existing sde service?
