Vinay Sharma, So the big question is are you using FlexViewer 2.1? You can not take a widget developed for FlexViewer 2.x and use it in the Sample Flex Viewer 1.x or a non FlexViewer project there are to many dependencies that you will have to re-code.
Vinay Sharma, If after you have added streetview.mxml to your flex project modules list and it is still not getting a swf built than the reason is that there is an error in the code or your configuration that is preventing it. You need to look for errors, to do this go to the window menu and click Problems and see what is listed there.
Georgianna, Yes you have to add the widgets mxml file to your flex projects modules list for a swf to be built. To do this right click on your flexviewer project in the package explorer window and choose properties then click flex modules and browse to the widget's mxml file and add it.
