Hey Andrew, To determine where the problem is, run the model using OLS and examine the VIF value for each explanatory variable. If some of the VIF values are large (above 7.5, for example), global multicollinearity is preventing GWR from solving.
More likely, however, local multicollinearity is the problem. Try creating a thematic map for each explanatory variable. If the map reveals spatial clustering of identical values, consider combining those variables with other explanatory variables to increase value variation.
Another option is to try transforming it (although not in the traditional sense of logs or powers): create a new field, then calculate the values to be the value (in this case the log) minus the mean for all values in that field. This doesn�??t actually change anything (the impact on results), but for some reason we've found that GWR likes variables in that form�?� and this transformation will often �??fix�?� the problem.
Also, just a reminder to make sure that you find a properly specified OLS model before moving on to GWR. There is some great documentation about this, including this recent ArcUser article on Finding a Meaningful Model and the training seminar on Regression Analysis Basics.
Hey Andrew, Another option is to try transforming it (although not in the traditional sense of logs or powers): create a new field, then calculate the values to be the value (in this case the log) minus the mean for all values in that field. This doesn�??t actually change anything (the impact on results), but for some reason we've found that GWR likes variables in that form�?� and this transformation will often �??fix�?� the problem.
