When autocomplete is enabled for the geocoder widget, if a user choses to press enter instead of selecting from the autocomplete drop-down, it throws the following error: Error "Error: This deferred has already been resolved at Error (native) at d (http://js.arcgis.com/3.10/init.js:73:478) at resolve.callback (http://js.arcgis.com/3.10/init.js:75:350) at q._receivedResults (http://js.arcgis.com/3.10/js/esri/dijit/Geocoder.js:31:116) at null.<anonymous> (http://js.arcgis.com/3.10/js/esri/dijit/Geocoder.js:28:18) at http://js.arcgis.com/3.10/init.js:174:23 at c (http://js.arcgis.com/3.10/init.js:74:221) at d (http://js.arcgis.com/3.10/init.js:74:10) at resolve.callback (http://js.arcgis.com/3.10/init.js:75:350) at null.<anonymous> (http://js.arcgis.com/3.10/init.js:754:70)" This is the case even in your sample at this url: Geocoder Widget | ArcGIS API for JavaScript . Is there a workaround or patch for this? Is there a way to disable whatever event (submit or keyup?) is triggering it?
Thanks, Jules
Thanks, Tim. The issue I seem to have with it (at least in my code), is that subsequent searches using the autocomplete fail, so the user would have to refresh at that point to keep using the geocoder. I will email them.
Best,
Jules
Hey Jules,
I just tested it and you are right. Even though it throws this error, it still takes me to the right place. Thats at least something
You should send an email here js_feedback@esri.com
They should be able to answer you.
Tim
