Hi,I tried the following code that was posted in this forum. I can see what appears to be the KML layer however It renders extremely small (almost a dot). It appears to be a projection issue however I am not sure what I am missing. Also the graphic count of the layer is 0. OpenFileDialog openFileDialog1 = new OpenFileDialog();openFileDialog1.Filter = "KML files (.kml)|*.kml|Compressed KML files (.kmz)|*.kmz|All Files (*.*)|*.*";openFileDialog1.FilterIndex = 1;bool? userClickedOK = openFileDialog1.ShowDialog();if (userClickedOK == true){ System.IO.Stream fileStream = openFileDialog1.File.OpenRead(); var layer = new KmlLayer(); layer.SetSource(myFiledDialog.File); myMap.Layers.Add(layer);}
