Hi,Are you using a data entry form (apl, for example?). If so, you can have Map.PointerZ in the "default value" field of a control, this will get populated for you automatically. Alternatively, you can use field calculator tools in ArcMap, after the field capture, to explicitly calculate Z values to a field that you designate for this data. Let me know if you'd like me to explain more.
The GPS and Antenna that I am using is collecting sub-foot accuracy for XY coordinates after post processing, so i figured it should be able to collect at least sub-Meter accuracy for Z-Value. Am i making false assumptions here?
Okay, I can figure that part out. But how do I view the actual Z-Value values (Numbers) in ArcMap??
